So if I change out the valve springs to match what is recommended, what's the harm with running the different rocker ratios? I'm currently at 1.5 intake and 1.6 exhaust... |
Edelbrock Cam #7102 ENGINE: CHEVY 283-400 V8 RPM RANGE: 1500-6500 Duration at 0.006" Lift: Intake: 308° Exhaust: 318° Duration at 0.050" Lift: Intake: 234° Exhaust: 244° Lift at Cam: Intake: 0.325" Exhaust: 0.340" Lift at Valve: Intake: 0.488" Exhaust: 0.510" Timing at 0.050" lift: Open Close Intake: 10° BTDC 44° ABDC Exhaust: 59° BBDC 5° ATDC Centerlines: Lobe Separation - 112° Intake Centerline - 107° Note: Use only stock ratio rocker arms. CAUTION: Use Edelbrock Performer-Link Timing Chain and Gear Set #7800 or Accu-Drive gear drive #7890. Do not use late model timing chain and gear sets that are designed for emission-controlled engines. These timing sets are machined in a retarded position and are not recommended for this camshaft installation. Edelbrock Timing Sets feature three keyways for specified timing selection. Use "0" position for most applications. Do not use dual valve springs.Use only recommended Edelbrock Sure Seat. Valve Springs #5703. Use stock ratio rocker arms only. Summit Cam #1107 Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 3,000-6,500 Intake Duration at 050 inch Lift: 234 Exhaust Duration at 050 inch Lift: 244 Duration at 050 inch Lift: 234 int./244 exh. Advertised Intake Duration: 292 Advertised Exhaust Duration: 302 Advertised Duration: 292 int./302 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in. Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift Lobe Separation (degrees): 114 The double spring warning is for the tyros out there who would throw a set of 150 lb seat pressure springs and expect the cam to break in w/o issue- obviously the cam doesn't give a whit about the spring being a single, dual or triple- as long as the pressures are within the range of what the cam needs to keep the lifters in contact w/the lobes, and not so high as to cause the cam/lifter to gall and/or have the lubrication fail. Had nada to do w/the heat treat. Using a 1.6 rocker arm isn't recommended for much the same reason- an experienced engine builder knows it's better to spec the cam for a 1.5 ratio rocker from the get-go, instead of buying a cam w/specs that require a 1.6 rocker to get the lift that's needed. Inexperienced builders will often make mistakes that cause coil bind or other things that cause the cam to fail. It's easier for Eddy to just say "Don't do it!", than to try to explain how to do it RIGHT. Less returned cams that way.
Cobalt327, excellent reply! Thank you for the response.
I have zero complaints with the performance of the engine and thoroughly enjoy the hp I get at the top end but don't feel it is a good fit for my application. This engine would be amazing in a car but my K30 with 38's (4.56 gears and SM465) doesn't have the low RPM grunt I'd like. Is there a cam out there that provides similar top end hp but provides low end grunt? I'm probably asking for the unachievable (best of both worlds)... Sounds like i should replace the 1.6 with 1.5 rockers; I didn't have a reason for running the different ratio other than I already had them. Will this make a noticeable difference in performance? |
Thanks for the info guys, I will take a look at the cams you are recommending and will check the spring pressure prior to install.
I'm currently running an MSD Distributor with the MSD 6AL controller box. I haven't messed with the distributor b/c everything works great throughout the entire power band... just doesn't have the low power grunt I'm looking for in the truck. I hope I'm not painting the wrong picture with the current set-up, I can light up the 38's pretty easy as long as I'm ~4k RPM or higher. I just feel like I'm driving a 2 stroke! The SM465 and 4.56 gears net me around 3k RPMs at 65-70 mph... |
| Edelbrock Performer RPM cam | zildjian4life218 | Engine | 6 | 11-07-2009 09:06 AM |
| Edelbrock performer or edelbrock thunder avs? | eric32 | Engine | 1 | 09-07-2009 11:25 PM |
| Edelbrock Performer vs Performer RPM vs Air Gap RPM | Regal Beagle | Engine | 10 | 02-16-2009 07:07 PM |
| Comparing 2 Edelbrock carbs ....EDELBROCK PERFORMER and AVS THUNDER | Calderone | Engine | 6 | 09-28-2008 09:24 AM |
| Edelbrock performer RPM | 1985fiero | Engine | 3 | 05-17-2004 05:03 AM |
