Edelbrock Performer or Thunder AVS?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2005, 10:40 PM
wickster's Avatar
Just putting the final touches on my 350ci SBC, comp xe 268H, performer intake, Sealed Power Flat Top pistons...running a TH350 in a 65 Chevelle.
I was thinking of selling my Performer Carb and getting the Thunder AVS? Would it be worth the change?
Don't know much about them except that they are Vaccum secondaries instead of mechanical on the performer?
Old 02-28-2005, 09:07 AM
spinn's Avatar
i know the flange is different,but have you looked into a square bore style holley .holley makes probably/arguably the best carb out there. a adapter plate works fine. stick with vacuum secondaries.
edelbrocks,carter,rochester,quadraJ(not that bad) dont have the tuneability of the holley. on a performance motor i want the extra adjustments.
Old 02-28-2005, 06:29 PM
lluciano77's Avatar
The Holley 4011 is a killer carb. The 650 DP would work very well. The old Holleys are stoneage technology. The new Holleys use all the same tune up parts and have some new tech add ons. They also have the one gasket above fuel level like the Q Jets. They are cheap on Ebay. I guess people just didn't like the look. I think they are allright.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7956410 515&rd=1&ssPageName=WDVW
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7956440 911&rd=1&ssPageName=WDVW
Old 02-28-2005, 10:20 PM
The secondary air valve is screw-adjustable on the AVS, whereas on the Performer (AFB), it's not. Otherwise, they're about the same.
Edelbrock Performer head #60909 Houman SS '70 Engine 4 01-20-2009 10:56 PM
Is there any advantage in running a BG speed demon over an edelbrock performer carb? batman09 Engine 49 07-02-2008 08:51 PM
Edelbrock Performer 390 vs. RPM Byrdie Engine 5 08-09-2004 08:02 PM
Edelbrock Thunder Series carb kaddylowrider Engine 1 11-06-2003 03:09 AM
Edelbrock performer fuel pump on a 77 gmc 400CI? 77chevy400 Engine 1 07-09-2003 01:17 AM
