edelbrock pro flo efi problem, no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2010, 05:57 PM
The problem I'm having is that the I added the pro flo efi system to my 383 chev. small block. and I have no spark. So I checked if i had 12v. to my coil and I don't. I traced the wires back to my ignition amplifier. Not sure how to check the ignition amplifier with a meter to see if its good. What should the voltage be at the ignition amplifier which is coming from my ecu? My understanding is the voltage power comes from the ecu than goes to the ignition amplifier. From the ignition amplifier the power goes to the the coil and than the distributor. On my hand held screen no error come up and all sensor are reading. I'm thinking that my computer is bad. If that's the case how do I repair or replace the ecu?
edelbrock pro flow question BLZR81 Engine 0 02-18-2010 10:25 PM
383 efi spark advance question ASAP 383silverado Engine 4 07-17-2007 01:16 PM
Edelbrock Preformer carb problem?? 79ElCamino Engine 3 09-24-2003 01:44 PM
Edelbrock 1405 problem BrackneyC Engine 26 09-23-2003 10:48 AM
Spark problem. CET Engine 6 04-23-2003 08:52 PM
