edelbrock pro flo injection wont start after running out of fuel - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2009, 09:09 PM
Nothing else changed, ran out of fuel, put more in and now it won't start anymore, cranks but won't fire, 377 all aluminum built small block with edelbrock pro flo I injection system
Thanks
Old 11-20-2009, 12:17 AM
redlightning's Avatar
Can you hear the fuel pump run?
and..............Welcome to the site.
Old 11-20-2009, 03:27 PM
Thanks
FI fuel pumps need the passing of fuel to cool them, check the pump it may be dead.
Another enemy is dirt in the tank, running low to out of fuel tends to to suck the crud into the pump, the inlet filter may be plugged, the pump damaged, or the outlet filter plugged. If it got past these places the next stop is regulator and injectors.
Running out of fuel is never good for the components that deliver it to the engine, but with fuel injection it can be a deadly and costly sin.
Bogie
Old 11-20-2009, 03:59 PM
Is the fuel pump wired thru a relay with the computer turning on the relay not the fuel pump ? If the computer runs the fuel pump as in the early system this sometimes burns out the computer.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
running whole new fuel system ?'s maxkroll Hotrodding Basics 2 02-12-2009 10:59 AM
edelbrock pro flo/ holley commander htwheelz67 Engine 6 04-05-2004 07:53 AM
Edelbrock Pro Flo 3500 Questions TurboS10 Engine 9 09-12-2003 09:26 AM
Edelbrock performer fuel pump on a 77 gmc 400CI? 77chevy400 Engine 1 07-09-2003 12:17 AM
