Edelbrock Pro Flow2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2008, 11:23 PM
Edelbrock Pro Flow2
Hi im deciding on induction for my 383 sbc and the thought of high gas prices makes fuel injection look pretty good. Now the Pro Flow2 is rated from 1500 to 7000 rpm and says it will support up to 435 horse, i was aiming for 450 on this motor so im wondering if this system would be up to task. Also is anyone else has this system, any problems with it, is it pretty easy to tune. I haven't played with fuel injection before so i need something thats straight foreward and easy to install/setup. Thanks, Jake
Old 08-12-2008, 12:23 AM
The ProFlow systems are easy to use and the support materials are quite good. What you think you'll make for power versus what you actually will make are two different things. You will likely be just fine. The systems are very reliable and replacement parts are OEM type stocked at local auto parts dealers like Napa and Autozone, MAP, IAC, fuel filter, TPS and so forth.
To be absolutely safe you'd want a system with 30 lb injectors. I suspect on the Pro2 they are installing 28.
edelbrock pro injection 3500 timing Rubber_Ruiner Engine 0 09-22-2007 04:17 PM
Few Q's about Edelbrock Pro Flow and such 71 c-10 Engine 11 02-20-2007 10:03 PM
Edelbrock Versus Pro Dart 1. sexypizzaman Engine 2 03-28-2006 11:31 AM
edelbrock pro flo/ holley commander htwheelz67 Engine 6 04-05-2004 08:53 AM
