Edelbrock Qudarjet secondaries - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2002, 01:37 PM
New Member
Post Edelbrock Qudarjet secondaries
Having a hard time figuring out how to get my secondaries to kick in sooner and with more gusto. Anyone with a clue pls. chime in.
This is a new Edelbrock quadrajet 795 cfm w/ vaccum secondaries.
Old 05-05-2002, 02:47 PM
Thumbs up
I need more info not familiar with edelbrock carbs. but they all work the same. do they have a spring to replace for the secondaries :p if they do triaL and error lighter spring until you find the right respose.hope this helps ( wrenchturner )
[ May 05, 2002: Message edited by: wrenchturner ]
[ May 05, 2002: Message edited by: wrenchturner ]</p>
Old 05-06-2002, 12:10 PM
New Member
Wink
step down to a weaker spring and re- jet
:p
Old 05-07-2002, 05:58 AM
New Member
Post
I found on the left side where there is a small set screw that holds the secondary butterfly spring in check. Cut that loose and use a screwdriver to set the secondary butterfly spring tension did 1/2 the trick. The spring was set way to high. Now on to re-jetting the secondaries. Thanks for the clues guys. Unfortunately I'm beginning to see that I might have been better off with a double pumper in consideration of the Muncie wide ration 4 speed?
I'm just beginning to crack the potential of this engine...but am trying to do it right...wires, coil, curve etc. Too bad gas in these parts is so inconsistent. One bad tank and I'm back to square one.
Old 05-15-2002, 04:47 PM
72 chevy's Avatar
Post
i hear ya 56, gas is very inconsistent up here in north central ks.
Old 05-15-2002, 05:04 PM
FASTFORD's Avatar
Post
dont be to upset. i have had, seen and heard of similar problems with holley. its still a little trial and error with either carb. the edge with edelbrock is the ease of making changes. hang in there and take your time. also you could contact edelbrock with as much info as possible and they will tell you what spring and jets to start out with.
www.edelbrock.com
update us with the results. luck.
Old 05-15-2002, 08:15 PM
Post
Once you get teh Q-jet tuned right, the beauty is they usually stay there. Holley is a lot easier to tune, but I hear a lot more guys having to go back in and re-tune periodically.
Good luck with it.
Old 05-17-2002, 04:46 AM
New Member
Post
Man, it's the little things. First, the distributor had slipped and there was a small vaccum leak at the carb base plate. She's purring NOW!
I'm at 10 degrees advance on the distributor (not counting vaccum advance) and NO ping whatsoever. Gonna start moving that up until I her some pre-detonation. Sound good?
