Edelbrock RPM Air Gap quality - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 06:52 PM
Hi guys.
I thought these were supposed to be as-cast to closely match a FelPro 1205 Intake gasket (SBC application). After checking my gaskets vs AFR heads, and the gaskets vs the Eddy Air Gap, it looks like the Air Gap needs up to .12 removed from the port walls to match. Any similar experiences?? Did you port match?? Port matching seems problematic becases the port isn't nicly tapered all the way to the cylinder head joint. It looks like hours of work to avoid a converging/diverging/converging port after grinding.
Pat
Old 02-08-2006, 07:04 PM
NAIRB's Avatar
Pat,
If the intake opening is slightly smaller than the cylinder head, you have no problem.
As a matter of fact, there will be no noticeable power decrease. You just don't want any areas of the head protruding into the path of the incoming air fuel charge from the intake aperature.
Are the intake's port openings fairly straight and uniform, just smaller?
I've had some of the professional products stuff and they are horridly crooked.
Old 02-08-2006, 07:40 PM
They're a little misaligned, as well as undersize. I was pleased to note that there is no place that the intake port would overlap the head, but .125 is a LOT of mismatch, doncha' think? It has to impact performace. If you reduce the port area by 7-10%, it seems to me you are limiting flow capacity. Correct??
Pat
Old 02-08-2006, 08:23 PM
NAIRB's Avatar
You would be surprised to know that the real answer to that would be not quite as much as you would think.
Just don't assume that your intake openings need to be as large as the gasket. That's always a mistake, and the areas of port cross sectional areas where the intake runners meet the cylinder head are usually straight and high flowing.
This is the first area where novice head porters want to grind on, but in reality, these areas net little gain in terms of increased airflow.
The bowl areas, and any area with a turn in it and the valve seat are ultimately the limiting areas in terms of airflow. A port can only flow as much area as it's most restrictive portion of the port. The intake aperature ain't it most of the time.
Old 02-08-2006, 09:02 PM
camaroman7d's Avatar
Brian is steering you in the right direction. It is not always the "size" of the port that matters. Velocity matters as well. You won't hurt anything by port matching the intake, you won't see huge gains either (if any). Personally on performance builds I like to port match, that's just because I can't help it.
Edit: You have to remember this intake will be used on everything from bone stock heads to large runner heads. If they made the port fit the large heads, what would they do for the stock heads?
Royce
Old 02-08-2006, 11:03 PM
You have no issues. Bolt it on.
Old 02-09-2006, 05:40 AM
Last journal entry: PICTURE TEST
intake
Remember felpro makes gaskets, they don't design intake runners......
Porting to a gasket always cracks me up....
You will see zero difference,,,, Try this assemble the engine, go race the crap out of it untill you know for sure what times it runs, then come back port the intake to match the gasket and go race the crap out of it again... I got a dollar that says zero difference....
Keith
Old 02-09-2006, 07:31 AM
engineczar's Avatar
Another thing that people do in error is that they match the heads to the gasket, and then the intake to the gasket. Then just bolt it on thinking that they've matched everything when in reality they don't take into account how the manifold fits the engine between the heads as assembled and torqued down. So instead of having the air/fuel flow with an unobstructed flow to the valve they actually now introduce overlaps between the manifold and heads. You're just better off with the intake smaller to take into account all the variables when it's assembled.
Old 02-09-2006, 09:49 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Sometimes that edge creates a fuel sheering piont that can reintroduce the fuel into the air stream.
Your mileage might vary .1 per gallon.
Old 11-24-2006, 10:26 AM
Duke of Cruel's Avatar
Car nerd
Originally Posted by PatM
Hi guys.
Pat
Its because the manifold also should fit smaller runner applications.
DoC
Edelbrock Air valve?? voodoosurfer Engine 5 12-10-2013 10:16 PM
GN Votec verses Edelbrock RPM Sky65 Engine 16 11-26-2005 11:18 PM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
Edelbrock RPM vs. old LT-1, Corvette manifolds 59vette Engine 1 01-24-2005 05:16 PM
Air Gap vs. Weiand, Performer/RPM, Holley, etc. (again!) acr Engine 10 12-05-2004 06:50 PM
