Edelbrock RPM Heads, SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2011, 08:24 PM
Thoughts on these heads? Good....Bad....OK? I picked up a very low mileage used set for about half of new price. Plan is to use them on mild 350.
Thanks
Old 03-04-2011, 09:23 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Can't speak personally about the specific heads but as with any used buy I would suggest getting them checked by a good head shop. If they are in good shape then the cost of checking them over will be minimal, if not then better that you know before they go on, may need to spend a bit more to have them setup and good to go but just do it if its minor fixes IMO.
What are the cc of the chamber, the runner volume, the max lift and the spring pressure are good things to know among others, you can confirm some of these on your own via model number. It is always best though to cc the chambers so you know for sure what you have, maybe the heads were milled or messed with in some other way.
good luck with em.
Old 03-04-2011, 09:27 PM
327NUT's Avatar
Depending on which model # head and the REAL conditon of the heads you have they will be fine for a mild to pretty warm build. They are not race heads and some guys I've read on here say they are "junk"....not so.
I had a pair of #60899 heads on my 331" sbc and they performed very well. If they are 64cc heads make sure your compression won't be too high (with your pistons) for the street. Iwould have them checked before you install them, just never know how they were used prior to your purchase.
Thanks
They are "supposed" to be unmodified. I think you are right though. I'll get them checked.
Old 03-04-2011, 09:32 PM
Leoman's Avatar
These heads are advertised at 185cc port volume, which ought to be ok for a mild build. I haven't used them because I'm a bit allergic to aluminum (I hate helicoil), but one thing I'd be sure of is that they haven't been brinelled (indented) by the head gasket rings, particularly if your intended new gaskets don't match up to the indentations.
Old 03-04-2011, 09:40 PM
Custom10's Avatar
Originally Posted by Sky65
Thanks
Good call. So tell us more about the engine plans,,,hot street, driver or what?
Old 03-05-2011, 08:07 AM
i just put a set on my 355 and just broke in the cam. they seem good but the road here are muddy and 4 feet of snow, so it will be a month or so till the roads are driveable. living on a main dirt road sucks.
Old 03-05-2011, 08:55 AM
The car is a 65 vette driver with a 69 350/350, 11:1 comp, currently 186 heads 2.02/1.6, Hooker sidepipes, Richmond non-od 5sp with 3.08 rear. Right now has Edelbrock EPS manifold with 750 Demon but going to Edelbrock 3X2 intake with small base Roch carbs, progressive linkage. Also going to a Howards retro roller cam, recommend here.
Old 03-05-2011, 09:14 AM
Custom10's Avatar
Ah yeah the 63-67 are my favorite vettes, sounds like a nice setup,,,let us know how those heads spec out.
TJ
Old 03-05-2011, 10:14 AM
TJ
It's not exactly origonal...
Old 03-05-2011, 04:58 PM
Custom10's Avatar
It has a cool "meaty" look, very choice vette right there, nicely done thanks for the pic.
That 5 spd must be a blast
TJ
Old 03-05-2011, 06:38 PM
License plate is great!
Awesome car by the way.
Old 03-05-2011, 08:55 PM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
Love that era Vette..and yours is very nice. Bet it runs great and cruises with the 5spd..
Old 03-05-2011, 09:06 PM
327NUT's Avatar
Reminds me of my brothers '63 split window ...but he sold it back in '68. It was a theft recovery, it was cherry but missing engine and trans. We built our first 327 for it, 4 spd., we glassed on fender flares and my Dad painted it marina blue laquer (gorgeous!!!). Installed REAL American magnesium torque masters with Firestone red steak tires. Turnred out very nice, like I said he sold it a couple of years later.........for $1700!!
Old 03-05-2011, 09:38 PM
Thanks for the comments.
The wife and I plan to do the Hot Rod Power tour this year...long haul. I hope we make it without incedent.
Edelbrock Heads TroyBoy Engine 8 05-24-2010 06:32 AM
Edelbrock rpm heads monster mouse Engine 1 02-05-2010 12:59 AM
Edelbrock Heads BBCMudbogger Engine 10 01-03-2006 05:55 PM
Edelbrock E-Tec Heads vs- Edelbrock Rpm`s. KeithB123 Engine 3 10-26-2004 07:39 PM
edelbrock e-tec heads nastynova Engine 2 03-13-2003 07:42 PM
