Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock rpm performer heads 350 vs 383
Old 11-05-2012, 04:01 PM
ssmonty ssmonty is offline
Originally Posted by hcompton View Post
Never take a dremel to an aluminum head. Its too easy to trash the head. Also they are fine stock no need to mess with them unless your trying to make over 500 hp. Electric die grinder is what you need but not dremel you need low speed for aluminum heads. high rpm of dremel will eat into the head to fast. Air power is no good for alum heads either same issue and also stalls at low rpm.
@ssmonty that was a swirl device you removed. The air must spin around the valves and into the combustion chamber. that is why they leave the sharp edge around the seat pocket. you can clean it up but not take it out all together. Unless replacing it with a real full on pocket port job. Edelbrock did not cut major corners they just didnt pocket port the heads. You didnt either. Rule of thumb for aftermarket heads is only port them if you have too by class. Other than that buy the next size up. Once you max out your heads then maybe go back for the 10 hp the manuafacture left on the table.
@O/P leave your heads factory. Have the valves checked to see if they are seating up. other than that just leave them be. They can be ported and could use some work from the factory. But you will make 400hp without going to the trouble.
HCOMPTON,
The ridges around the valve seat inserts were not swirl devices. Some chambers on the head had them and some didn't. It was left from the machine operation at the factory to install the seats. I believe a machine operation be it by CNC, or manual mill, or something else was used to cut the bore to the same depth for each chamber relative to the table height of the machine. However each chambers casting depth wasn't consistant thus the ridge on some chambers and not on others.
If your refering to a vane downstream of the valve guide, there wasn't one on these heads. I did reduce the diameter of the guide bosses to reduce air flow restriction although it won't make that much of a difference, similar to the reduced valve stem diameter of the Manley "Pro Flow" valves I installed. I figure every little bit helps as far as beating the next guy.
If your refering to a swirl vane in the chamber such as a raised boss around the spark plug location, there wasn't one in my heads.
As far as a "Rule of thumb for aftermarket heads is only port them if you have too by class" thats the first time I've heard of that. I have heard of no porting allowed in certain classes. As far as I'm concerned I had the spare time and the will to try to make them better than stock before I installed them on an engine vrs removing them to do the same later.
Just MHO.
To each his own,
ssmonty
