edelbrock secondary - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2002, 11:04 AM
Post edelbrock secondary
I recently installed an Edelbrock performer on a stock 350. I can't get the secondaries to open and there isn't any real adjustment on it that I can find to get them to open sooner. Any suggestions?
Old 10-17-2002, 11:28 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
From what I remember on the edelbrock I had and hated before I went to Holley, The secondaries will only open when the engine is under load and at full throttle. The are vacuum operated with a counter wieght to keep them closed untill needed. I never was able to tune it where there was no hesitation. I think this is due to them actually opening to soon, and a lack of accelerator pump volume.
Go to a Holley. They are much more tunable. The edelbrocks work fine on a streeter. I just like things very crisp, and the afb will not do it.
chris
Old 10-17-2002, 12:03 PM
Post
This carb has a mechanical secondary system. I don't think there is enough throttle play to open the secondaries. I'm thinking that if I bend the accuating rod a bit, they will pull open sooner. Any thoughts??
Old 10-17-2002, 01:27 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Don't do it, It's not gonna help.
Old 10-17-2002, 01:49 PM
New Member
Post
Secondary throtle plates are mechanical but there is air valve above the boosters so it is vacuum system.
or its something i never seen before
i havent found a good way to tune that air valve, drilling material away from counter weights is one possibility but its difficult to get back if you remove too much.
it is possible to hang it open and it did work at my engine, but not every engine of course.Well i didnt notice any difference at power anyway so i did return
to vacuum operated.(or is it flow operated?)
After i read your second topic second time, secondary
throttle plates should open when full throttle. is that carb new? primaries open full? it is progressive system so if you get 2/3 open it wont much move secondaries but after that they should get fully open.
Old 10-17-2002, 06:19 PM
TurboS10's Avatar
Wiki Edits: 2
Post
[quote]Originally posted by ron2424:
<strong>This carb has a mechanical secondary system. I don't think there is enough throttle play to open the secondaries. I'm thinking that if I bend the accuating rod a bit, they will pull open sooner. Any thoughts??</strong><hr></blockquote>
That is just to insure they dont open too early, they are still vacuum operated.
Chris
Old 10-17-2002, 07:48 PM
drgnwgn289's Avatar
Post
Does it have an electric choke? If so, the secondaries will not open unless the choke is off. You can fix this by putting a little blob of silver solder on the right place, work the carb a few times by hand and you will see what I mean.
