How are you plumbing the carbs, as in what type adapter to do the 2, 2-bbl's through the 4-bbl. intake? Are you going to use progressive linkage? Any thoughts on the idle circuit and such? But AFA the intake itself, it would be as good a choice as any for velocity, I would think. And that's helped by your rather low RPM ceiling. There was a "Streetmaster" intake that kind of fits w/what you're doing. I don't know but what the good old Performer intake might not be just as good as either of those obsolete intakes... |
you are right about the looks over performance....not much kick to the 318...i was told the performer doesnt pull enough vacuum. if i bumped up the cam to a stock 340 cam and ran some 360 heads that flow more i could go with the performer and may do so in the future.....but this old vintage intake is a high velocity intake with really small runners (smaller than stock) but moves the air a lot faster....and .......it's just different...as is a dual 2 1973 carters (with metering rods) on a muscle car. i will go with a progressive set up....trying to now figure out the idle circuit....in concept if i used all 4 idle screws, i question.....will this act like a holley 4 corner idle set up. or i can shut the back one off and just use the front primary carb for the idle. dont know what to do for the squirters. thought about removing the accelerator pump to the back carb and just use jets back there. going to run 2 carter bbd's or rochester 2g's. the carters would be harder to tune with the metering rods but would run better and have a smoother fuel curve. i hate to but i will have to use a carb spacer. vintage speed sells an adapter for a 4 to 2x2 set up for $85. Then the matter is just figuring out a custom linkage and trying to get it to work
if you can find a 318 street master let me know.....i think it's a better intake. the weiand 3000 is as well |
lolThe 2G has good support, I'd probably lean (he haw) towards those. If I were doing this, I'd want to at least try to use the 'secondary' carb as if it were one of the end carbs on some trip set-ups, w/closed off idle circuit and tuned to run similar to the secondary side of a 4-bbl. This should work fine, unless you find you have some sort of unforeseen fuel distribution problems that can't be dealt with. Unless you want to fab up the linkage from scratch, just get a cheap-o (they're ALL high, though...) triple 2-bbl progressive linkage and use what you need of it for your 2x2 set-up. |
AFA one of each... I dunno... lol
I have an SP2P on the 9.0 to 1 318 in my '86 D150. It has a 727 and 2.94 gears. The engine is internally stock except for a .020" overbore, a 6619 600 Holley and 1-5/8" headers. Performance off idle to 4,000 is decent for a big old barge with tall gears but when you hit 4,000 that is it, period. Gas mileage........ we don't mention gas mileage and my truck in the same breath.
gas mileage. let's talk gas mileage here. what are you gettin hippie? do you like this manifold or would you rather have a performer? in your opinion.....hands down...is this the best manifold for a dual 2 barrel carb set up with a dead stock 1976 smog 318 with smog pistons and 273:1 gears?
The stock intake usally is bet for milage out of a stock engie... |
If you want to try something different, the carbs for a Corvair are already set up for one as a primary and one as a secondary. My 140 has 2 primary carbs and 2 secondary. That solves the idle circuit issue. Linkage is progressive.
ok....so for a 2x2 set up. 2 carters or 2gc rochesters. 1976 stock smog motor.....2:76 gears.......stock cam. i will run an adapter plate for the 2x2 to 4 barrel adapter. what manifold should i run...i have a 2 barrel manifold now.
| Edelbrock Torker Intake Manifold | Pilot | Engine | 7 | 08-07-2011 08:42 PM |
| porting intake manifold? | sexypizzaman | Engine | 11 | 11-06-2009 10:26 PM |
| Intake manifold not sealing? | Biscuit6447 | Engine | 13 | 10-02-2009 09:05 PM |
| Leak on top of SBC 350 intake manifold | 75gmck25 | Engine | 9 | 01-23-2009 09:11 AM |
| Building A 302 Chevy | Scorpio Shaping Flow | Hotrodding Basics | 6 | 01-16-2007 05:55 AM |
