Read it, followed it, no results. Been battling this for 4 years. |
vac advance not dropping out fast enough?
linkage tipping into the primaries? timing starting to soon with to much? sticking and/or worn advance? sticking, slow reacting rods vacuum plungers? |
Rods are new and free, springs are the 7" vac flavor. |
Greg,
plug the vac adv into the ported nipple and just do a quicky/crude idle screws adjust for a steady Hg idle needle and then blip the throttle.... post back if better/worse/no change |
Been there done that. Makes it a tad worse, but not appeciably. |
Sounds like the front float is a tad too low. BTDT
I bet the runner velocity is a tad slow at idle and you are getting a little bit of fuel pooling. The richer float might help it a little. Sometimes setting the idle up another 100 rpm helps the velocity enough to stop the pooling. The other thing I would try is a 4 hole tapered spacer to smooth the transition of the atomized fuel from the carb base to the runner/plenum volume thus eliminating the sharp corners stops the fuel "droplets" from slinging out of the airstream onto the side of the plenum. I'd bet money it wouldn't do it with a 600 because of the smaller bores. Does it seem that the intake air temp makes a difference? Last edited by ScoTFrenzel; 08-19-2008 at 06:47 PM. |
Here's what i did tonight. I took a #28 squirter out of a 600 and replaced the #35 that came with the 1407, put the pump on the leanest stroke. Rsults, much much better, but could use less yet. 28 is the smallest they install but I'm going to check out the site for accessories to see if I can grab a smaller one yet. It is getting too much shot. BTW, cant use a spacer. I have exactly 1/4" hood clearance. |
Greg,
my $.02: your squirter change does make sense.... (you have the reverse of a common radical cam low Hg problem, the normal squirter shot is "used up" before the hg recovers enough for the primaries to work) the Edelbrock idle gas flow circuit is independent of the primaries so there is always a transition "hump" as the primaries take over your cam (215/225?CRS) is small enough that there is plenty of low rpm Hg signal for the primaries work during the transition with no load on the motor.... because your cent timing is starting virtually at idle (700rpm), which does add Hg,,,,with no load on the motor, there is no 0Hg moment during the idle to primaries transition when the primaries don't work and you would need a big plunger shot.... the standard squirter sizes are on a chart towards the front of the manual (?CRS) my next move would be to change the springs tabs so that the cent doesn't start till 1,000-1,200 (which is more typical for your cam) and test that with the present smaller squirter... with no load on the motor and very light springs, the cent weights inertia often adds to much timing to soon when you "blip" the throttle.... I didn't list squirters with the "probables" because the RPM tall intake and bigger than needed carb would typically need a normal squirt..... (dang CRS!) doesn't the ZZ motor have "fast burn heads"? if yes then 32-34* is likely a better WOT TT edit add: with only a 1/4" hood clearance(!) I'd add shim to the driver side motor mount or use a chain so the motor movement when you launch is restricted....so the air cleaner edge can't scratch/rub the hood.... Last edited by red65mustang; 08-20-2008 at 09:03 AM. |
No fast burns. It has the L98 Corvette heads. 194/150 with 58cc chambers and 10:1 static. I have super stiff urethane mounts to keep that mill rock solid. She hasnt touched yet.
thanks for the memory jog hearty chuckle!!!....
I shared your "price pain" on my last build.... had to buy and pay shipping on a full set of specific size valve spring shims to get the 2 additional shims I needed....none of the local engine shops had that size lol...what my wife "never" knows can't hurt me right? do post if the even smaller squirters work, may help somebody later on |
| Edelbrock Performer head #60909 | Houman SS '70 | Engine | 4 | 01-20-2009 09:56 PM |
| Edelbrock stumble? | western star | Engine | 11 | 08-13-2008 05:10 PM |
| Stumble or secondary delay in Edelbrock 750 | Detroit Muscle in NZ | Engine | 6 | 10-22-2007 02:13 AM |
| Edelbrock Pro-Flo Problems | Unkie | Engine | 11 | 05-22-2007 05:20 PM |
| edelbrock stumble | smlblcks10 | Engine | 4 | 06-21-2005 06:00 AM |
