Edelbrock.....super rich at idle?? Are the metering rods up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 11:51 PM
wickster's Avatar
I read all the posts on this issue but none really have the answer?
350 SBC, CompXE268 cam...brand new rebuild.
Timing is at 12 degrees and I am getting 13 in vacuum at about 800 rpm. That is the most vaccum I can get by adjusting the idle screws. Car seems to run great at all speeds but still running way too rich at idle...my eyes burn in the garage.
Where do I start? Is it possible that the metering rods are in the "power mode" at idle? I changed the springs last year in my old 327...but the fuel washed the color out and I don't know what they are. Any suggestions on which spring to use?
Old 04-22-2005, 12:46 AM
What carb do you have? In case of Edelbrock, here is online manual + some recommendations from the author:
http://www.telusplanet.net/public/gi...delbrock_1.htm
Regards!
Denis
Old 04-22-2005, 07:15 AM
cboy's Avatar
Last journal entry: Finished
If you have the other springs from the E-brock spring kit, you should be able to tell which ones you have installed by laying them out with the others. There is a variation in size as well as color. I could be wrong about this but I doubt it is your springs that are causing the rich condition at idle. My understanding is the springs control rod movement under throttle - something like back pressure to the vacuum forces - and the rods should always return to the idle position. Have you pulled the rods and cleaned them up real good? Maybe on of them is sticking in the bore. Another possibility off the top of my head is that you somehow got a mismatch between your rods and your jets. This would be possible if you (or a prior owner) has done a lot of different tuning on the carb. Each jet size will only work with a couple of rod sizes (these matche ups are shown in the on line manual).
Always learning...and sharing what I've learned.
Old 04-22-2005, 08:49 AM
wickster's Avatar
Sorry...carb is an Edelbrock 1406 (600 CFM)
Old 04-22-2005, 10:28 AM
wickster,
go to that link I posted and find the chart for 600cfm carb. Take your carb off the intake, open it up (easy - 5 minutes) and take a note of which primary and secondary jets you are using. Write down which metering rods you have installed. Then refer to the chart and see where approximately you are going to be. Also, check a few other things there: how far the fuel bowls are located, power valve etc.
I am using a purple (7 in HG) spring in mine. After going through Q-jet, dissassembly of a Edel. (Carter) carb is a piece of cake. I had to buy the Edel. tune kit that comes with a bunch of rods, jets and springs.
Post your findings here, that'll definitely help us troubleshoot your problem.
Regards!
Denis
Old 04-22-2005, 11:14 AM
wickster's Avatar
I have the tuning kit....and I am running Reference Point #8...can't remember which springs...I'll check tonight.
Also think I will take it apart and recheck the floats.
Old 04-22-2005, 11:41 AM
Wiki Edits: 49
I suspect all you need to do is change the metering rod springs. The springs work on vacuum and if they are too strong for your engine vacuum level at idle they will not compress and you will wind up with a rich condition.
Old 04-22-2005, 02:28 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
we just installed that cam in a 327 10:1 motor. HE had the 7 inch springs on his too. But if you think about going from a stock cam with about 20 inches at idle to the 268 which has about 12, it make sense that you'd have to step down your springs a little bit too, because with that little vacuum to start with you're going to lose a lot in a hurry even with just a touch of the trottle. You don't want to have them bumping in too early, my guess is a 7 inch spring will be too much. I would use a 3 or 4.
K
Old 04-22-2005, 06:17 PM
wickster's Avatar
OK...found my setup sheet. Here is what I am running right now.....
Calibration Point #8
1455 Rod, 1426 Jet (6% Lean in Cruise)
1425 Secondary Jet (4% Lean)
Pink Spring (7")
O yeah...and we are at 3750 ft elevation.
Old 04-22-2005, 07:37 PM
I would try leaning it out a little bit more - use rod 1426, position 7. Which position is your pump drive link?
Old 04-22-2005, 08:05 PM
cboy's Avatar
Just had another thought. Have you checked your choke plate to make sure it sits at the fully open position at idle?
I'm still very hesitant about the wrong spring theory. It's easy enough to check (by swapping out the spring) but my guess is you will just mess up your throttle response - which you indicated is fine at present.
Darom's suggestion of the position 7 rod/jet is worth a try. Even 12 if 7 doesn't do it.
Old 04-23-2005, 12:30 AM
wickster's Avatar
Tried the Yellow spring (4")....NO GOOD. Drives fine...but when cruising at about 2800 and I punch it....kind of chugs a little then takes off....sounds to me like a lean condition. I hooked up the vac gage and when I punch it from idle (not in gear) I get a minimum of 5"....so I think the Pink (7") spring is right.
Pump drive link is on the top hole.
I will try position #7...tomorrow.
Thanks for the help so far.
I think I am getting there on the "drivability"..its the idle that is gassing me out of the garage....I am going to check the floats too tomorrow.
Old 04-23-2005, 08:18 AM
Steve karch's Avatar
The step up spring wont effect idle as far as I know. They only come into effect when running off the idle circut. What I suggest is to hook up your vacuum advance to the manifold port (full vacuum at idle). This will bring your base idle up (as it will advance your timing) then back off on the base idle screw. Then, adjust your mixture screws for best idle vacuum. This will bring the throttle plates back onto the idle circut. I think, from what you describe, that you have uncovered the idle slot and are idling on the main circut. My 406 idle at aprox 13" vacuum and when i was running an Edelbrock (now have a Holley 750 hp dp) it would do the same as your engine at idle with either no vacuum advance or with the vacuum advance hooked to port. This basic tune up principal applies to either Holley or Edelbrock when running larger cams.
Steve
Old 04-23-2005, 12:07 PM
wickster,
your pump drive link is hooked up to the top hole? This is the setting which needs to be done for 750 carbs. Yours should be in the middle hole.
Here is a paragraph from the rebuilt manual I have:
"Back out idle speed screw to allow primary throttle valves to seat in bores. (Models 1405-1406-100) Install pump connector rod in the second hole from top of pump arm. Bend pump rod to obtain 17/32" (1,35cm) from top of pump shaft to bowl top."
Old 04-23-2005, 01:25 PM
cboy's Avatar
I don't understand this section of your post. Could you explain a little more what you mean by the idle slot and how it can become "uncovered".
Thanks,
Dewey
5.565 or 5.7 rods? JohnyR17 Engine 9 10-09-2010 08:17 PM
Vacuum advance western star Engine 14 11-30-2009 11:28 PM
How metering rods work in Rochester Dualjet ? Olds 69 Engine 1 02-18-2005 03:56 PM
running super rich at idle??? ocbaud Engine 4 11-21-2004 03:21 PM
edelbrock carb. still too rich! TVR383 Engine 9 09-03-2003 03:27 PM
