Edelbrock tunnel ram water leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2013, 11:18 PM
Hi I am wondering if I am making a mistake, by taking off my dual quad performer intake, and installing a new edelbrock tunnel ram?
I went and let that picture of Edelbrocks chrome tunnel ram get me, it is really nice looking, but I have notest a few things and having a tiny problem and now wonder if I should put the performer intake back on?
Here's why, I noticed there is no water jackets in the tunnel ram intake, also I did not see the recommended silaconing if the tunnel ram intake bolts and now I have a water leak on the driver side front bolts, Also the carb linkage had to be changed from progressive to both doing the same thing with a straight rod between them. I am now wondering if I will have any over heating problems? I have a small block 400 with 12:1 compreson pistons, mild cam, no lope. it ran great with the performer intake. sence I installed the tunnel ram, ive had some problems getting it to start up good and run right.
I think I can get the tunnel ram to work, but I am concerned about street driving and the water jacket not in the tunnel ram intake? will this cause problems? I love that 600 dollar intake, it looks bad ***, but I am wondering if I should trade off looks for better performance?
Here is the tunnel ram I bought :Edelbrock 71101 Edelbrock Street Tunnel Ram Intake Manifolds for Small Block Chevy
Any ideas? Gary
Old 04-10-2013, 07:38 AM
You can make it work , search here & other places , there is lots of info. AFA water passage , there is 1 in the frt to feed the therm. like normal , no passage in the back is normal w/most manifolds.... leaky bolt , use some teflon thread sealer [not tape]. !:1 linkage is prefered for tunnel rams.
dave
Old 04-10-2013, 07:45 AM
delawarebill's Avatar
leak'n
i used hi temp sil sealant on mine and no problems.. i also used a tunnel and now an airgap both with no center water passage. not a problem either..
tunnel ram intake
Tunnel ram Kendall03 Engine 8 02-07-2011 08:33 AM
sbf hi ram tunnel ram 72fordlb Engine 9 04-13-2009 05:15 PM
Setup up of Edelbrock Street Tunnel Ram silverT Hotrodders' Lounge 1 03-09-2006 10:33 AM
Tunnel ram OR NOT ?? ss crazy Engine 11 09-09-2003 10:57 AM
How to -Tunnel Ram sedan_dad Hotrodders' Lounge 0 01-20-2003 10:15 AM
