Edelbrock Victor Jr intake street manners - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-22-2011, 07:12 PM
Landshark928's Avatar
FrankenPorsche
Here's another pic of the screw mod. Grind one side of the bolt flat. Keep trying it and grinding it until you get the advance band you need. I have my initial at 24* and about 14* of mechanical advance with the bolt flat to the threads on one side. Make sure the bolt is short enough not to interfere with the mechanism below it.
Here's mine from the side where you can see how long the bolt should be.
And here is another I found in another thread.
  #32 (permalink)
Old 07-22-2011, 07:14 PM
v8hed's Avatar
AK427
Thanks, this is something on my 'to do' list for tomorrow
  #33 (permalink)
Old 07-23-2011, 07:58 AM
v8hed's Avatar
AK427
UPDATE: I've put a limit screw on the advance mechanism and have now set things up for 22* initial, 34* total all-in by 2500-3000rpm. Leaving the vac. can disconnected until I install an adjustable (which I have laying around).
I'm making 7.5" hg vacuum @ 950rpm idle... sound right?
I've read about the method of setting initial timing using a vac gauge... should I do that instead? I haven't tried yet, but if I advance it more (and put more limit on the mech. advance accordingly), I might be able to get better idle vacuum. I don't actually NEED anymore idle vacuum for anything, but would this be better for the motor? I was just following advice on here by setting the initial at 22* (was previously set at 14*).
Oh, the cam is a big-ish solid (248*/248* @ 0.050)
  #34 (permalink)
Old 07-23-2011, 08:25 AM
Get it up temp. and road test it. Find a good incline that you can climb in high gear and see if it pings at various throttle positions & rpm. Advance timing until it does, then back off about 2 degrees. IMO
ssmonty
  #35 (permalink)
Old 07-23-2011, 10:44 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Now that you have your base timing and mechanical adv setup I would leave it be. Setting timing with engine vac is a quick way of ball parking things. No need for this when you have a light IMO. and this method also works best with stock engines anyhow. It would be interesting though if you could try the base timing at 24-26 and check to see if the idle vacuum increases, i doubt it.\ try it. The carb mixture settings can effect eng vac as well.
What carb? if holley make sure the power valve is matched with engine vac and same for eddy but its the rod springs.
One test drive will not tell you if your base+mech is where it should be so leave it for a while and put some miles on.
Leave the vacuum gage on the manifold vacuum source and record the eng vac levels under all load conditions while driving including when downshifting to aid braking, then do it all over on ported vac and record those too.
Then install your vacuum can and test out the movement of the advance mechanism vs vacuum levels, use a vacuum pump and gage with the motor off and record the levels. Fire it up and and see how much timing is being added while using the vacuum pump on the can, record the level of advance compared to vac "wg, record that too. yeah information is power
Following up on the application of vacuum advance.
Most adjustable vacuum adv cans start to add advance at about 5" wg. That is with the set screw fully turned in CW. This is a list of adjustments on a crane type
All in CW the rod travel starts at approx 4.8"wg and ends at 10"wg vacuum
3 out CCW 5.2 start end 10.7
5 out CCW 5.8 start end 11.8
7 out CCW 6.8 start end 13
9 out CCW 7.3 start end 14
11 out CCW 7.3 start end 12
13 out CCW 8.0 start end 12
(ps i would advise against more than 11 turns out you can dislodge the set screw PITA)
With the cam you have the motor may never make enough vacuum to add all of the vacuum advance available in the distributor. You may see some vac adv at light cruise loads if the eng vac is high enough, you won't know till you go for a spin with the vacuum gage connected, but some is better than none. Chances are you will end up with the set screw all the way in and on ported vac so the vacuum advance is out at idle. The idle vacuum most likely is jumping around and this will cause havoc with timing at idle if on manifold source. Glad you were able to "screw" with your mech adv limit, your half way there.
  #36 (permalink)
Old 07-23-2011, 11:38 AM
v8hed's Avatar
AK427
Thanks for all the info.
Carb is a stock Holley 750DP... even the stock jets were perfect on the dyno. I'll do a forum search on power valve selection
Idle vacuum was fairly steady... it jumped around a bit, but only between 7 and 8" hg. I'll try adding some more initial to see if the vac goes up.
Thanks.
850 DP to Victor or Victor Jr Intake for BBC 31fordcoupe Engine 0 06-21-2010 06:25 PM
Edelbrock Victor 2+2 Single Plane Intake Manifold Z28 Camaro Kid Engine 4 09-23-2009 09:09 AM
What Intake Victor Jr or Super victor 66sedanman Engine 3 03-01-2008 02:01 PM
Powerglide street manners questions. RObs71Nova Transmission - Rearend 6 08-02-2005 09:21 PM
Edelbrock Street Master Intake? Kenny13z3 Engine 7 11-02-2004 10:34 AM
