Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edelbrock VS Carter AFB
Old 09-18-2006, 07:19 PM
Centerline Centerline is offline
Wiki Edits: 49
Both carbs are manufactured on the same line at Weber the only real difference is the metering rods. The Edelbrock has a slightly different step sequence than the Carter. Both are excellent carbs and require very little tinkering to get them to run right, unlike Holleys that require a whole lot of adjusting to run correctly.
