Edelbroke manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2009, 03:20 PM
Edelbroke manifold
I have a jet boat with a 454 Chevy bigblock .Holley marine carb 715 Cfm ,what is the best choice in manifold ,i have the edelbroke performer Rpm dual plane ,My mechanic has a edelbroke torquer single plane ,carb sits off center on the single plane.Thanks
Old 06-14-2009, 04:24 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
You're likely better off with the Performer RPM. I've seen a similar combo; 460 Ford with a marine dual plane (large dual plane with polished runners) - this is on a jet boat also.
Guy at the speed shop talked the owner into a Torker and it went from about 5500 RPM to 5200 at WOT. Definitely picked up low-end but at expense of top speed. It kinda turned it into a high performance tug boat.
Old 06-14-2009, 04:57 PM
Thanks for your input
Leak on top of SBC 350 intake manifold 75gmck25 Engine 9 01-23-2009 09:11 AM
Broke manifold bolt now it leaks a little did more damage with my extractor. orvillewho Engine 4 05-22-2008 11:10 AM
1996 Ford 460 Exhaust Manifold Problem! Solution? BobnSofi Engine 0 05-10-2007 09:56 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
Weiand Manifold question Andrew7dg Engine 1 08-30-2004 12:03 AM
