Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edlebrock Valve Cover Breathers???
  #30 (permalink)
Old 11-25-2012, 05:15 AM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
The easiest solution is to connect the pcv to the rear of the block where the road draft tube is located, behind the distributor, I have done this a dozen times. You leave the stock open breather alone in the filler tube, and run a hose type pcv to the rear of the carb, or screw in type- screwed into the vacuum port in the rear base of the quadrajet! The v112 valve is made to run from the road draft breather tube to the pcv port in the carb on a 327 Chevy!
