Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edlebrock Valve Cover Breathers???
  #42 (permalink)
Old 11-25-2012, 11:49 AM
Sweet-34's Avatar
Sweet-34 Sweet-34 is online now
Lost In The 50's
Originally Posted by streetrodderbn View Post
the road draft breather tube is bolted down to the rear of the block. You probably have a soft plug that was bolted into the hole. I know Ecklers Corvette has the replacement fitting. The tube coming out of the stock adapter is the 1/2" that the pcv valve you identified for the 327 is! Do you know if the road draft breather canister is still in the block? You can see it after removing the plug someone inserted by using a mirror and looking toward the front of the block. it's under the intake manifold, and you won't be able to see into the lifter valley if it is still in place.
Does it make a difference whether the cannister is in there or not?
Looked in Eckler's Catalog and didn't find anything like you stated. Thanks
