If I take that out what do I use to install in the hole to attach a pcv valve to the baseplate of the Quad? Are you saying that the V112 is the one to use? It has a 1/2" barb with the flow going to the 3/8" barb. Whatever goes in that hole must have a way to attach a 1/2" hose to the V112 PCV Valve. Thanks for your response. |
It's only necessary if you don't want the fumes.
PCV valves are emissions related, it doesn't "help" the engine to have it. As a matter of fact burning oil fumes in the combustion chamber isn't a positive for horsepower and performance. |
Isn't the job of the PCV Valve to regulate the amount of suction from the intake? Very little suction at idle and almost none at full throttle.
I really don't know....just a thought. I seen a setup like I suggested on a 327 V-8 Corvette with Tri-Power and he claims it works perfectly. Hooked up directly with no PCV. Would there be a problem at idle if it was drawing full suction? As I stated earlier....I really don't know and am just throwing out the topic for discussion. ![]() See attached picture. |
..... it was discovered in 1958 that the road draft tube was a major source, about half, of the hydrocarbons coming from the automobile. GM's Cadillac Division, which had built many tanks during WWII, recognized that installation of PCV on vehicles could bring the first major reduction in automotive hydrocarbon emissions.
Happy Reading... ![]() Crankcase ventilation system - Wikipedia, the free encyclopedia |
Is PCV Valve really necessary?
I have read your other post. I really don't think you were understanding some of the threads that were posted. As you say you have fumes in the engine compartment. The purpose of the PCV valve is to pull the gases from the crankcase and pull them into the intake manifold to reburn in the engine again instead of to the atmosphere. The PCV valve regulates the vacuum pulled thru the PCV system. That is why your idea will not work. Here is an article on crankcase ventilation to give you a better understanding than I can explain. Crankcase ventilation system - Wikipedia, the free encyclopedia
Well I'll be, I guess I type too slow.
secont time,,,, run the PCV hose into the headers.This will not change the tune and it will draw the fumes.
an air pump will actually add power,if you have the room,,both solutions will work. |
Is a PCv valve really necessary?
I saw this adapter on a old post that may be of interest to you.
ssmonty http://www.google.com/imgres?imgurl=...ed=0CB4Q9QEwAQ |
the road draft breather tube is bolted down to the rear of the block. You probably have a soft plug that was bolted into the hole. I know Ecklers Corvette has the replacement fitting. The tube coming out of the stock adapter is the 1/2" that the pcv valve you identified for the 327 is! Do you know if the road draft breather canister is still in the block? You can see it after removing the plug someone inserted by using a mirror and looking toward the front of the block. it's under the intake manifold, and you won't be able to see into the lifter valley if it is still in place.
Looked in Eckler's Catalog and didn't find anything like you stated. Thanks |
the internal canister acts as an oil separator. It would be best if it is still in place, most people don't just remove it unless there is a reason. You will find all you need from Danchuk Part # 13282- you can view it online. it replaces the top piece you don't have!
'66-67 Corvette Oil Fill Tube With PCV Valve
In the event you end going with the '66-'67 vette pcv in the filler tube here are some photo's and Links:
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B http://www.parts123.com/parts123/yb....Z5Z5Z50000050B http://www.parts123.com/parts123/yb....Z5Z5Z50000050B http://www.parts123.com/parts123/yb....Z5Z5Z50000050B ![]() ![]()
Add PCV
I looked up Danchuck #13282 as you posted and see that it is for 1955-1957 Chevrolets to eliminate the Road Draft Tube and replace it with a PCV Valve setup. My '67 327 V-8 did not have a road draft tube but a different type of PCV setup for that year which somebody eliminated (plugged) when they put the Edlebrock Valve Covers with Breathers to make it look cool. I'm assuming the Danchuck #13282 would accomplish the same thing on my '67 327 V-8 if I choose to go that route. Lakeroadster and anyone else feel free to add your imput on this Danchuck #13282 setup. Thanks again to everyone for your patience, pictures and posting on this subject.: |
| Valve Cover Breathers | Canadian Charlie | Engine | 3 | 07-30-2009 06:47 AM |
| Valve cover breathers | Mikeymuy | Engine | 1 | 03-07-2009 12:34 PM |
| valve cover breathers | sparkyct55 | Hotrodding Basics | 13 | 03-10-2008 09:59 PM |
| valve cover breathers? | hotrod haven | Engine | 7 | 04-30-2007 09:58 PM |
| Valve Cover Breathers | trick66 | Engine | 1 | 03-17-2003 08:46 PM |
