Educate me about shifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2006, 10:01 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Sadly, I really don't have any experiance with aftermarket auto shifters. The one thing I know is I would need a T handle type instead of a pistol grip as I kind of sit over, not next to the shifter. Also want something small in size as there's not much room in the T bucket. I looked at B&M's website, but theres all different kinds. I really don't need all the extra stuff with triggers and lockouts. What's been your experiance?
Old 03-08-2006, 11:19 AM
Skylark_77_455's Avatar
My dad used the Hurst pro-matic 2 in his T. It is a cable operated so you can mount them in different places. It has about a 6"-7" arc travel and is fully rachet on the up and down shift. And they make a T handle for it.
Old 03-09-2006, 07:47 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Assuming your T is using an automatic similar to most T's I've seen.
I use a B&M Quicksilver in my T. It's a ratchet type shifter which makes it easy to go up or down through the gears without looking at the indicator or missing a gear, or just leave it in Drive and let the trans do the work for you. While ratcheting through the gears it will prevent an accidental shift into Reverse (you have to lift the shift handle up to shift into Reverse / Park, a feature I really like). I put a neutral starter safety switch on mine ($13 B&M part, attaches to a bracket built into the shifter base with two screws) and that is all I use. You can also add a second switch for backup lights. The console is larger than other units such as Lokar, but it does not get in the way as much as you think. Smooth, easy shifting. Good installation instructions. Will handle GM, Ford, Mopar setups. The linkage between the shifter and the trans is a cable, so mounting in an optimum location in the cockpit is easy, unlike some units which must bolt directly to the trans. My $.02.
pushbotton shifters wheel-7 Transmission - Rearend 3 03-07-2006 02:58 PM
push button shifters wheel-7 Transmission - Rearend 2 08-10-2005 04:13 PM
shifters mightycaminotw Transmission - Rearend 0 12-05-2003 05:52 PM
lokar style shifters spankthru Transmission - Rearend 1 10-25-2003 03:08 PM
ratchet shifters camino_man Transmission - Rearend 11 04-11-2003 07:17 PM
