eelbrock choke solenoid - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2009, 11:44 AM
Hi, my edelbrock carb on my truck that i just baught doesnt have the choke solenoid wired up. i've just left it open while its being ran but i need to know how to wire it up. Here is a link to a photo album with a few pics of it.
http://s820.photobucket.com/albums/zz122/ilcoalminer/
Thanks for your time.
Old 11-24-2009, 08:59 PM
excaliberprime's Avatar
Last journal entry: back for 2014
random stab in the dark
i cant see your photo because im at work and it will not show photo bucket images. you will want to make sure you are getting a full 12 volts for the edelbrock choke. im not sure what vehicle you have it in but i always run a wire from the ign circuit on my fuse block. if you don't want to go that route you can splice into another suitable Gage 12v wire with power feed only active in accessory or ignition( if you run it off an accessory it will be hot even if the engine is not running or heating up. an edelbrock tech once suggested the wiper power feed wire. there are a number of other wires you can run off of just would not run it off the distributor. the ground wire can be mounted to the carb its self. once you get your choke wired it will need to be adjusted usually especially if its been held open for a good amount of time. hope this helps.
Old 12-01-2009, 06:46 PM
fast68's Avatar
likes chevy trucks & boobies
ok its not a relay first of all
and there another thread totally identical to this already on here somewhere
one is for 12v hot and the other is to ground
really simple
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Ford solenoid on Chevy starter ??? Augusto Electrical 4 08-13-2009 01:59 PM
F150 issues ALL FORD Transmission - Rearend 27 06-30-2009 05:28 PM
Choke Questions, orvillewho Electrical 2 03-25-2008 02:01 PM
Choke Problem, Again!? Gokussj5okazu Engine 12 12-17-2006 09:32 PM
