Effect on differential with two different size tires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 06:32 PM
I have a car with 25 inch diameter tires on the front, and 29 inch diameter tires on the rear, with a generation 3 Corvette rear end. I would like to install a spare tire and it would have to be the 25 inch diameter size. (the 29's would not fit on the front).
My question is if I have a flat tire on the rear, would it have an adverse effect on the differential if I had the 25 inch diameter tire on one side, the 29 inch diameter on the other side, and drove the car 10 miles to get home?
If so any suggestions?
Old 03-01-2012, 07:03 PM
Last journal entry: My Last Hot Rod
Tire stagger
Nascar and local racers run what they call tire stagger larger diameter tires on one side of the car versus a small diameter on the other side. To make the car steer a or push. It never hurt their rear axels. Most are non detroit lockers.
Old 03-01-2012, 07:05 PM
This has been argued about for years, but it's the same thing as cruising on a long curvy mountain road. One tire has to turn at a different rate of speed from the other. Just keep the distance reasonable (don't get on the interstate heading for California), and you'll be okay.
Old 03-01-2012, 07:29 PM
nine4gmc's Avatar
agreed, as long as its a spare, and you treat it as a spare(not driving over 60mph and not too far or long periods), you should be all good!
Old 03-01-2012, 08:21 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Also agreed...What happens is the 25'' tire is spinning its side gear in the diff at 1 speed,and the 29'' tire is spinning it's side gear at a slower speed,putting pressure on that gear,as well as the center spider gears....a minor bind up,for lack of a better term....but by following NINE4GMC's guidelines, you'll be fine,if the situation arises.
Old 03-01-2012, 08:37 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Two things come to mind:
Are you running a Detroit locker?
Are the tires half full or half empty?
Old 03-03-2012, 08:08 PM
Wiki Edits: 85
No. .
Silverado differential cover size cutsupreme Transmission - Rearend 20 05-15-2011 08:58 AM
What size tires? TroyBoy Suspension - Brakes - Steering 4 02-20-2011 05:26 PM
What size tires to go with? oldtimercarnut Hotrodding Basics 2 10-17-2010 08:13 PM
1981 Parisienne differential size? abas_abas Transmission - Rearend 4 07-16-2009 07:52 AM
85 Buick Regal Differential size hungrietaz Transmission - Rearend 3 04-07-2008 07:57 PM
