-   -   Effective volume on piston (http://www.hotrodders.com/forum/effective-volume-piston-230399.html)
KyleG 03-06-2013 07:57 PM
http://i1088.photobucket.com/albums/...902_143814.jpg
I am trying to come up with an around about cr. These are the flat tops in my 355. I think the deck clearance is around .030. The guy at the machine shop said it is very possibly, he did not measure though. He also said with the 64cc Double hump heads, it is probably around 10.1 to 11.1. The motor is all the way together, running. So to late to measure now..lol What IS effective volume? And What do these look to you? Of course, you guys wont be able to give me exact numbers, just wanting around abouts.
ap72 03-06-2013 08:42 PM
You're probably closer to 9:1. What part number is on the pistons?
KyleG 03-06-2013 08:45 PM
No idea man. Its already thrown together.. /: And I was thinking it was that low.. Hoping it was haha Cheaper gas. Been running 93, because I thought it was higher than 10:5
BOBCRMAN@aol.com 03-06-2013 08:50 PM
Nowhere near 10-1. Those pistons look like rebuilders pistons, note the large double valve reliefs and front large notch. All bleed off compression. Plus most rebuilders pistons are .020" short
KyleG 03-06-2013 08:54 PM
Goood! Soo regular gas is goood to run??
ap72 03-06-2013 08:57 PM
Maybe. Maybe not. The joys of messing with a "mystery engine"
KyleG 03-06-2013 09:08 PM
Very true!
painted jester 03-07-2013 09:45 PM
that #3 piston (2nd one back) looks like its got a bad spot above the ring land at 2 o clock is it damaged or just a bad photo? These eyes are old!!! :drunk:
Jester
KyleG 03-07-2013 09:53 PM
Its just a real bad photo, it was a little carbon build up..
BigMo 03-08-2013 05:57 AM
Yeah, youre like 9-1 or so....those 4-brow pistons have like 6 to 7.5 cc loss of volume....and with that large of a deck (.030) you are down quite a bit......unless the heads are shaved to the max and the chambers are like 62 or something w a really thin head gasket.....
KyleG 03-08-2013 08:09 PM
I dont think the heads are shaved any, and stock spec head gasket. Filled up on regular and can't tell a difference. So probably around 9:1 thankfully lol
cobalt327 03-09-2013 11:44 PM
You have a 1 point range of between about 9.2 and 10.2:1 depending on the block deck, gasket thickness and whether the pistons are 1.56" or 1.54" compression height.
The problem at the low end of the CR shown is the quench distance will be VERY wide (as much as 0.086" w/a 0.045 piston deck caused by a rebuilder piston combined w/an unmilled deck along w/a 0.041" gasket thickness).
As long as it'd not detonating, at least it shouldn't beat the bearings out of it or pinch a ring.
KyleG 03-13-2013 06:43 PM
Hard to say. Its running fine though. I'm just gonna drive it lol Drives smooth, pulls smooth. Sometimes may have a little bog. But thats part of it I guess
lg1969 03-14-2013 11:07 AM
1 Attachment(s)
I use this cal
hcompton 03-14-2013 02:14 PM
Most four vavle reliefs without the dish are 6 to 12 cc's But the deck hieght is the most important here. Zero deck or .045 in the hole makes a big difference.
