Nowhere near 10-1. Those pistons look like rebuilders pistons, note the large double valve reliefs and front large notch. All bleed off compression. Plus most rebuilders pistons are .020" short
that #3 piston (2nd one back) looks like its got a bad spot above the ring land at 2 o clock is it damaged or just a bad photo? These eyes are old!!!
![]() Jester |
Yeah, youre like 9-1 or so....those 4-brow pistons have like 6 to 7.5 cc loss of volume....and with that large of a deck (.030) you are down quite a bit......unless the heads are shaved to the max and the chambers are like 62 or something w a really thin head gasket.....
The problem at the low end of the CR shown is the quench distance will be VERY wide (as much as 0.086" w/a 0.045 piston deck caused by a rebuilder piston combined w/an unmilled deck along w/a 0.041" gasket thickness). As long as it'd not detonating, at least it shouldn't beat the bearings out of it or pinch a ring. |
I use this cal
| The Following User Says Thank You to lg1969 For This Useful Post: | ||
KyleG (03-18-2013) | ||
Most four vavle reliefs without the dish are 6 to 12 cc's But the deck hieght is the most important here. Zero deck or .045 in the hole makes a big difference.
| TRW Piston head volume | thinwhiteduke | Hotrodding Basics | 13 | 02-18-2013 03:38 PM |
| Dish piston volume for 1977 - 350 V8 ? | wade786 | Engine | 2 | 08-08-2011 10:10 PM |
| Piston surface volume | BadA$$37 | Engine | 15 | 01-02-2008 07:39 PM |
| Theory: Intake volume vs cylinder volume / engine vacuum | 59vette | Engine | 6 | 04-29-2004 12:03 PM |
| dished piston volume | RedRocket | Engine | 0 | 01-05-2003 02:43 PM |
