Your hot oil pressure isn't excessive, especially if this is a fresh engine. You might be getting some oil bypassing the filter if so equipped. I like to block the filter mount's bypass off w/a pipe plug.
You're not bulging the oil filter at cold start-up, are you? |
The big thing about too much pressure is exploding oil filters. Otherwise, pressure that is too high might suggest oil that is too thick which can cause excessive cold start wear. That cold start pressure is awfully high. At those pressures, the bypass is fully opened, no oil is getting filtered, and its probably about like molasses. 10w30 in most of my chevy builds puts me at about 60 psi cold startup, then 20 hot idle and 60-70 hot redline.
More isn't better. Correct is better. Your 10w40 pressure numbers look great, in fact a little high at cold temps. Going to 20w50 would definitely be a move in the wrong direction. Slight loss of power, definite loss of lubrication protection, potential for exploding your oil filter. |
Agree with Curtis. Would go to a thinner multi-grade oil such as 5W-20 until the bearings clearance themselves.
Thanks everyone for the tips. I will revert back to a thinner grade oil. I was just hoping the heavier weight would "help" with my other issue of possibly needing a re-ring. Now suspect rear main (2pc) or rear of oil pan is leaking under load and making mess and difficulty to track oil consumption. I guess a re-ring and gaskets is in order. I just have a bad feeling that there is something complex going on (factor of few things not one). For example just fixed PCV system (missing breather). All the local performance machine shops have differing opinions, for example talking about head change, cam change and carb swap. Already have $$$ in this build which is all new parts and only 700 miles.
| High Oil Pressure 283 | nickeldimerods | Engine | 40 | 08-24-2007 10:40 AM |
| fram oil filter lower oil pressure | elvis 66 chevelle | Engine | 33 | 09-14-2006 04:36 PM |
| which oil pump for a 406? high volume or high pressure? | 406 ss monte | Engine | 23 | 09-10-2006 07:48 PM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
| oil pressure! motor new, start up 75 lbs ! now1lbs at1400 rpm | wantafastpass | Hotrodding Basics | 6 | 02-29-2004 11:54 AM |
