Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - From EFI to carb on a 5.0?
Old 06-28-2005, 12:05 AM
h8louzn h8louzn is offline
Make sure you get the right dist.gear.
You have a roller cam in there.
I like you combo if it had heads and cam I would stick with the 650.
If you are going to leave it stock I would go smaller.
I used a 600 with heads and cam and it was too small.
I did like the BG road demon vac. sec. worked great with stock heads and air gap intake.
Hope that helps.
