From EFI to carb on a 5.0? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2005, 11:55 AM
New Member
Last journal entry: '46 Ford coupe - engine buildup
All - I'm putting a 5.0 HO in my 46 Coupe. I have also decided that all of the wires, sensors, looms, etc. look like crap in an old car...sooooo I want to run a carb. I think all i need to do is the following:
rip all the wires off the engine
take the upper/lower EFI intakes off
stick on a RPM air gap intake with a Holley 650
get an MSD dizzy, ignition box, and coil
run the wires from the ignition to the dizzy, and dizzy to coil
throw in wires for the alt and starter
tune the carb until i can drive by a gas station without a sense of impending doom!
Is that about it?
Old 06-27-2005, 12:11 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
That's about it!
Old 06-27-2005, 06:39 PM
FEDDO's Avatar
carb
You will be happier with a smaller carb, and not a double pumper.
Old 06-27-2005, 08:40 PM
Max Keith's Avatar
EFI to carb
I think you will be happier with a 500-600 CFM vacuum secondary, and my bets are on the 500. A 500 will keep you well supplied up to and over 5500 RPM, and if you arent planning to hot up the engine a lot, why bother going any bigger?
Old 06-28-2005, 12:05 AM
Make sure you get the right dist.gear.
You have a roller cam in there.
I like you combo if it had heads and cam I would stick with the 650.
If you are going to leave it stock I would go smaller.
I used a 600 with heads and cam and it was too small.
I did like the BG road demon vac. sec. worked great with stock heads and air gap intake.
Hope that helps.
Old 06-28-2005, 01:06 PM
Technical Support Barry Grant
5.0 Carburetor
On a 5.0l you'd be really happy with a 575 Speed Demon carburetor. The annular boosters in it will make the throttle response and drivability excellent.
Carb or EFI, which one is better for my motor bigedd396 Engine 1 06-01-2004 02:41 PM
Carb vs EFI speedingpenguin Engine 6 03-23-2004 09:23 AM
CARB. VS. EFI khaotic89GT Engine 5 05-19-2003 04:39 AM
91 5.0 EFI Swap Joe S Engine 6 09-15-2002 10:53 PM
EFI 5.0 in an early mustang! 68stang_99 Engine 3 08-21-2002 11:58 AM
