EFI Chevy won't start. Why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2009, 10:11 PM
willys36@aol.com's Avatar
Wiki Edits: 21
A friend has a 1997 Chevy pickup w/ fuel injected V6. Just had it rebuilt and has a problem. It won't start unless he drips some gas into the intake then it takes off and runs fine. I know nothing about FI systems but this sounds like a plugged start-up nozzle of some sort. Pump seems to work fine since it runs, just won't fire off initially?
Thoughts?
Old 10-17-2009, 10:22 PM
briskedm's Avatar
check the fuel pressure and make sure it holds up at 60+ psi... the system requires that to run, 62+ is ideal on those scfi chevys, the system primes, then awaits the trigger signal for run, if it primes and doesn't hold the pressure no start...
Old 10-17-2009, 10:48 PM
Siggy_Freud's Avatar
If you have fuel pressure and its consistent while crankng, go to a parts store and buy a NOID light. It plugs into the injector harness and makes sure the injectors are getting the signal to fire.
Bringing history and technology together.
Old 10-18-2009, 11:01 AM
Thoughts?
These trucks use an oil pressure switch to power the electric fuel pump once the engine is running. Since the EFI needs fuel primed to start the engine, there is a second system that powers the pump for two seconds as soon as you turn the key to RUN. This is controlled by the computer and uses a relay to operate the pump. That relay is only used until the engine starts and the oil pressure switch closes. If the relay is bad, it will cause the symptoms you describe. An easy way to check is to turn the key to RUN (without starting) and listen for the pump. You may need to remove the gas cap and have someone listen at the filler neck while you do this. If you do not hear the pump, chances are the relay is bad. We know the pump is good, since the engine runs once you prime it.
Old 10-18-2009, 03:30 PM
Oh I totally missed the part where it runs fine once it starts hehe. Do what the guy before me said, he's on the nose.
Old 10-18-2009, 07:35 PM
Wiki Edits: 21
Now that sounds like something I was envisioning. Will check that out, thanx.
85 Chevy s-10: won't start, suspect elec probs now joe99 Electrical 7 12-15-2010 11:58 AM
HEI Chevy wont start if battery is low at all ? Berg Engine 20 07-16-2008 09:59 AM
Converting non efi to efi macx Engine 6 07-06-2005 07:28 PM
"49 chevy won't start erin810332 Engine 0 04-22-2003 08:39 PM
Chevy 502 initial start up edubois Engine 1 01-14-2003 04:47 PM
