EFI and manifold selection?
Hello,
Could someone answer me a question with regards to the RPM range of an intake manifold. I would like to put together a EFI setup and have a Victor Jr intake with injector bungs welded into it. My question is this: Edelbrock rate the Victor Jr. at 3500-8500 in a carburated setup, yet if you look at the EFI setup that Edelbrock sells, which uses the same manifold, is rated 1500-6500 RPM. WHat gives? Is it related to a air velocity having to pull fuel from a carb where as the EFI directly injects into each port? Help me understand.
Thanks,
Z
