Are you talking about the vacuum line?
If so, just plug it up. They also make nice caps that go over the outlet on the carb. I don't need smog inspection on my 76 C10 either but if I get stopped roadside by a smog cop, I would get fined for removing any pollution stuff. |
You got me confused.
You mentioned you will swap to a non EGR manifold. If there is no EGR opening on the new manifold then you won't need any block off plate because there is no hole for the EGR to block off. Make sense? |
sorry for the confusion, i guess thats why i came here to the forum. i didnt know what all the egr is actually connected to other than the carb...i would be swapping the intake manifold also and it would be non egr also...since i will be doing that i can simply remove all egr components and vacuum lines? what all could i remove? i have a diagram of vacuum lines in my manual but there are WAY too many diagrams for possible routing of lines and i just dont know which one actually applies...would removing the egr compromise any other components or does it operate by itself? if that doesnt make sense do tell
You can simply pull of the line and plug it.
| Edelbrock Carb Problem. | odieboy | Engine | 8 | 11-24-2009 02:20 PM |
| edelbrock carb problem | thelastdon15 | Engine | 4 | 10-07-2008 08:22 AM |
| Edelbrock Carb problem? | busterwivell | Engine | 9 | 07-29-2007 07:49 AM |
| Edelbrock carb problem | Tim Feeley | Engine | 2 | 07-31-2006 07:36 PM |
| Help, another Edelbrock Carb Problem | xxllmm4 | Engine | 3 | 07-07-2006 06:12 AM |
