-   -   to EGR or not to EGR, that is the question (http://www.hotrodders.com/forum/egr-not-egr-question-68894.html)
Bill Yarbrough 08-26-2005 07:57 AM
86 TPI 350 out a Corvette, completly stock going in an old Chevy. Do I want to use the EGR? The car is driven 20,000+ miles a year. What about performance and gas milage? Emissions are not a factor.
Henry Highrise 08-26-2005 12:15 PM
You would probably get more response if you posted this in the engine forum. Welcome to Hotrodders. :welcome:
1931 steve 08-26-2005 01:15 PM
I would not use the EGR Valve, just block it off. As far as gas millage I doubt it will matter.
Steve :welcome:
poncho62 08-27-2005 07:47 PM
moving to engine forum........An EGR valve has no bearing on performance. Use it or not.....same HP output.
jimfulco 08-30-2005 11:18 PM
EGR only functions at part-throttle, so full-throttle performance should not be affected. Part-throttle fuel calibration is dependent on EGR, and if the EGR is not working, it may tend to ping a bit during light acceleration or heavy loading. If the engine has a knock sensor, it may retard the timing, which might tend to reduce performance.
Jacks77 08-31-2005 01:04 PM
From reading the above, if there is no effect, then why use it at all? Just more junk on the engine. I blocked mine with an alumn plate.
Triaged 08-31-2005 02:51 PM
Originally Posted by Jacks77
... if there is no effect, then why use it at all?
1) Because it does nothing to hurt power output
2) Because the computer will throw a code if you remove it
3) Because it is against federal law (and in many places state law as well) to remove it.
4) Because it will help reduce NOx emissions making the air we all have to breath a bit better.
Siggy_Freud 08-31-2005 04:41 PM
Whatever you decide to do, make sure the chip "knows" what is going on. It has EGR dependent features. When all is said and done its almost easier to keep it.
WildBill 08-31-2005 07:48 PM
Leave it in!
The EGR allows exhaust gas into the cylinder during the intake stroke and, amazingly and counterintuitively, LOWERS cylinder temperature. THis lowers emissions and, when operating correctly as it almost always does with fuel injection, makes more power at part throttle, basically all the time, for tha amount of gas consumed by keeping the A/F ratio close to ideal. Leave it in.
BigDawgsEatFirst 08-31-2005 08:03 PM
we were taught in school to push in the diaphragm on EGR (On Chebbie)
and if working the motor would stumble(Running at Idle)
like unpluging a vacuum port
if you got fuel inject and ecm hooked up
leave it alone
find better gas and power somewhere else
Like earlier posts stated
they are 100% right
make sure it works
Jacks77 08-31-2005 09:30 PM
[QUOTE=Triaged]1) Because it does nothing to hurt power output
Okay
Well, my 77 don't have a computer
Wrong! Depends on which state and how old your car is. Mine is 28 years and exempt.
Well then, that's gonna wipe out 3/4 of the hot rods on this board that don't run the EGR...
http://1-4u-computer-graphics.com/jwm77.jpg
Triaged 08-31-2005 10:07 PM
3) Wrong! Depends on which state and how old your car is. Mine is 28 years and exempt.
Your car needs to be 68 or older (66 if it is a CA car) to be exempt. http://www.shadetreemechanic.com/smo..._equipment.htm
and if you don't mind reading the whole thing (which has additions that even include alt. fuel vehicles)...
http://www.epa.gov/otaq/regs/fuels/cff/memo-1a.txt
Edited for more proper epa link...
sbchevfreak 08-31-2005 10:09 PM
Also prevents part throttle detonation at cruise speeds.
Siggy_Freud 08-31-2005 11:09 PM
[QUOTE=Jacks77]
Okay
This thread was meant to help the original poster of the question thus information posted should be relevant for his vehicle first and foremost. The things said so far are all true and great advice. While some advice may not apply to your car Jacks its great that all of it has been posted.
h8louzn 09-01-2005 12:08 AM
Not true!!
In CA your car is exempt if it is a 75 or older.....
Just checked into this again as I was going to help my nephew with a 76 mustang II Pro street...
OK, I typed to fast...
That is true but, you do not have to smog the car if it's a 75 or older..
So why would you worry about any of the requirement for that year car??
If you want to keep all that early smog crap on your car go ahead I will toss mine as it will never see a smog shop again!
