egr plumbing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 12:36 PM
I'm thinking about switching to an open element air filter system. Can I just remove the egr hose but leave tge rest of the egr system in place without ill effects?
Old 10-23-2013, 02:11 PM
LATECH's Avatar
The EGR does not hook to the air cleaner in any way.
Perhaps you are talking about the fresh air intake for the PCV system???
Fact is stranger than Fiction
Old 10-23-2013, 02:41 PM
I could be calling it the wrong name. There's a metal flexible tube coming from the passenger side exhaust manifold connecting to the air intake duct that goes to the fender.
Old 10-23-2013, 03:20 PM
Banned
that heats the incoming air for quicker warm up and better fuel atomization.
an open air filter system will be pulling in plenty of that hot air off the exhaust manifolds though- it may heat up even quicker!
Old 10-23-2013, 04:14 PM
Awesome!! I ditch it. The old tubing keeps falling off anyways.
Thanks for the help and correction. I still have a lot to learn.
Old 10-23-2013, 06:39 PM
The tube or flex hose from the mainfold to the air cleaner is there to provide hot air immidately after start up to help the fuel atomize and allow the carb or TBI to come off of start up enrichment faster as this not only causes a lot of pollution but eats rings, pistons, and cylinder bores shortening engine life by wiping what little upper end lubrication there is within any engine.
Properly working there should be a thermostatically operated valve in the air cleaner intake that opens the hot air channel when needed at cold start up and closes off that channel as the engine warms up and heat to force fuel atomization is no longer needed but the preference will be for cold outide air to enhance power output.
The trouble with open air filters is they pull in cold air when the engine is cold and needs hot air which reduces engine life; then they pull in hot under hood air when the engine is warmed up which reduces engine power.
These hot rod air cleaners look cool but are a loose/loose proposition. The factory engineers knew very well what they were doing with the original air cleaner system, you're way better to fix it so it works properly and then if you need more air to support more RPMs, bigger cam and carb, etc. then get a K&N filter that fits the housing and have the advantages of what the factory air cleaner system does for you with the higher flow rate and better cleaning of the K&N. This is a win/win proposition with longer engine life and more power. Leave the open element filters to the cool looking, clueless class of hot rodders.
Bogie
Air line plumbing question Warhammer Garage - Tools 1 12-27-2011 06:30 AM
Plumbing Question HotRodMan Off-Topic 4 05-17-2006 09:35 AM
to EGR or not to EGR, that is the question Bill Yarbrough Engine 19 09-02-2005 11:26 AM
Last fuel system plumbing question (I hope) william27103 Engine 1 07-08-2005 09:57 PM
plumbing question please help.... Gino Fultano Suspension - Brakes - Steering 1 08-29-2004 03:24 AM
