-   -   EGR valve (http://www.hotrodders.com/forum/egr-valve-143723.html)
SBCfan04 08-19-2008 07:14 AM
EGR valve
What is it? and how does it work?
richard stewart 3rd 08-19-2008 08:46 AM
Hi,
EGR = exhaust gas recirculation valve.
It's used to allow a portion of the exhaust gases to be routed back
into the combustion chamber to be re-burnt,
resulting in lower emissions & a cooler more complete burn.
Rich
SBCfan04 08-19-2008 10:14 AM
thanks..if the EGR valve is bad can that make a engine run rich or anything?
Jmark 08-19-2008 11:21 AM
It won't be rich, atleast not enough to notice, but you may find the engine more prone to pinging than before.
richard stewart 3rd 08-19-2008 11:27 AM
egr valve
If the egr valve is stick open it will cause,
rough idling, a vacuum leak, & hesitation.
if stuck closed it can cause knocking (pinging)
Rich
Jmark 08-19-2008 12:23 PM
Rich
Good addition! I forgot that they can stick open too. Seen lots of them back in the day.
