EGR valve
What is it? and how does it work?
Hi,
EGR = exhaust gas recirculation valve. It's used to allow a portion of the exhaust gases to be routed back into the combustion chamber to be re-burnt, resulting in lower emissions & a cooler more complete burn. Rich |
thanks..if the EGR valve is bad can that make a engine run rich or anything?
egr valve
If the egr valve is stick open it will cause,
rough idling, a vacuum leak, & hesitation. if stuck closed it can cause knocking (pinging) Rich Last edited by richard stewart 3rd; 08-19-2008 at 11:29 AM. Reason: spelling |
| Correct way to set valves on sbc w/ solid flat tappit camshaft? | Joshua Lee | Engine | 17 | 02-09-2011 05:55 PM |
| can i do away with egr valve? | Fordy8man | Engine | 15 | 08-23-2007 01:45 PM |
| EGR Valve 2005 Dodge Magnum 5.7 | cuda66 | Engine | 4 | 05-14-2007 06:26 PM |
| EGR valve operation | rick458 | Engine | 1 | 02-16-2005 12:10 AM |
| How do you know if your EGR valve is working??? | Munchos90 | Engine | 15 | 01-26-2004 09:29 PM |
