Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - EGR Valve in the way of new valve covers
Old 05-15-2004, 08:56 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
You should be able to find a EGR block off plate at your nearest part store. you could also maybe try and shave the side of the EGR valve, but if it hangs over too far, the block off is likely your only alternative.
