El camino brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 06:34 PM
not too familiar with the interchange of this age of vehicle. was wondering if i can put the front suspension from a 74 vette and put it on my 76 el camino. my reasoning for this is the quad piston brake calipers. i now i would have to change the control arms to accommodate the ball joints and spindles. any thoughts?
Old 10-22-2011, 08:11 PM
Last journal entry: Paint
You are better off leaving the brakes you have on there alone. The Vette brakes are more trouble. The 74 Vette brakes are the same brakes as they used in 65. There is nothing wrong with the single piston calipers. There are plenty of the 4 piston Vette brakes that have to have sleaves put in them.
Old 10-27-2011, 04:16 PM
ok. thanks. im starting to hear more and more bad about the quad calipers. guess i will stick with the stock single. i did just rebuild the calipers and put all new brakes and hardware in. just thought it would be a better system.
79 El Camino Rear Disc brake conversion Nailhead Suspension - Brakes - Steering 6 12-23-2012 09:22 PM
Help with my Brake conversion 1968 El Camino pittbull7934 Suspension - Brakes - Steering 0 08-04-2009 01:22 PM
87 el camino brake conversion jnickl Suspension - Brakes - Steering 2 01-16-2008 12:57 AM
71 el camino disc brake conversion stu_yoakam Suspension - Brakes - Steering 5 03-19-2007 04:34 PM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 06:01 PM
