el camino gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2005, 10:16 AM
el camino gauges
ive got a 1979 el camino and i want to put a 1983 dash cluster in it.im no genius when it comes to wiring.think this will work?
Old 09-01-2005, 11:33 AM
MI2600's Avatar
Member# 3287
I have an '86 and I thought the dashes were pretty standard between '79 and '87.
When I do similar type work, I label each connector as it's disconnected with cheap paper sticky tags. Then, as you reassemble and connect items you can just tear the tag off.
Old 09-01-2005, 04:29 PM
docvette's Avatar
Wiki Edits: 12
Cards
Doc here,
Do Both El Camino's use a cluster Laminate card?
If so get a Cluster schematic for both and compare wire functions at the plug , wire for wire..If the same, and the plugs will fit you should be good.
If you need to change out the plug be sure your wires match the pin numbers on the card as to function..same applies to any wire changes you must make.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
adapt 94 IFS onto 66 el camino Echofive Suspension - Brakes - Steering 5 05-21-2004 10:21 AM
EL Glow gauges for my '49 Chevy Truck hiimed Electrical 2 04-15-2004 02:28 PM
el camino fenders amish Body - Exterior 1 05-16-2003 04:31 PM
El Camino Song matt37015 Hotrodders' Lounge 4 01-14-2003 04:18 PM
el camino rear end ?? mac95 Transmission - Rearend 3 01-01-2003 01:26 PM
