EL camino rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2012, 12:52 PM
37 ford
EL camino rear end
I have a 65 tempest with a 1 leg in it . Could anyone tell me if a 70 El Camino rear end will bolt in without changing anything? Did the wideth change in 68?
Old 07-03-2012, 02:39 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Yes---the width changed in 68
1" overall wider
The later rear will bolt right in, but you will have to use the later model
springs as the earlier rear has different perches on the axle, and are bolted
down with a retainer.
Might have to double check backspacing on your wheels.
That extra 1/2" might have an affect on the tire rubbing the
wheel well.
Which rear end for a 73 El Camino bigkevy Transmission - Rearend 4 08-02-2010 12:02 PM
85 el camino rear end choices motorhead454 Transmission - Rearend 5 01-31-2009 09:46 AM
El Camino rear end rashster Transmission - Rearend 4 09-15-2004 07:49 AM
Rear end for an 85 El Camino mmeraz Transmission - Rearend 0 06-18-2003 11:23 AM
el camino rear end ?? mac95 Transmission - Rearend 3 01-01-2003 02:26 PM
