this is my first post ,if im speakeing out of turn please let me know. i have just come across a 454 and want to install it in my '81 el camino . i also want to install a ford 9in rear end in the el camino. does anyone know an easy way to do this . seem like if seen a 9in housing in a magizen set up for these types of GM cars does anyone know of this? or does anyone make the brakets to weld on the housing? also does anyone make header for a bbc that will fit in a el camino? thank you , james
call currie enterprise or randy's ring and pinion. for the headers call summitt racing.
my 80 camino has a stock width 70 mustang 9 inch with c e 4 link and some home made box& bracing, been working good enough to go 11.90
I have an 80 Camino that I put an L 98 'vette engine in. We also swapped out the original differential for a posi unit out of a 1986 Monte Carlo SS. It fit perfectly. The only changes were the speeedometer gear and the spline on the rear of the drive shaft.
If you REALLY want the Ford 9 inch differential Currie Enterprises makes one for about $2200.00 that will fit your Camino. Their phone number is 714-528-6957 and they are located in Anaheim CA. You can also find them on the web at <a href="http://www.currieenterprises.com" target="_blank">http://www.currieenterprises.com</a> Benji |
