el camino/ s10 front spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 05:00 PM
It is my understanding that there is a way to use certain S-10 front spindles that are for anti-lock systems in my '82 El Camino.
If anyone can confirm or refer me to a site that discusses this issue it is appreciated.
I have installed the '09 Pontiac G8 independent rear in the chassis and need to do the front brakes now.
Old 01-24-2011, 09:37 PM
ericnova72's Avatar
More for Less Racer
S-10 spindle is a direct fit and identical to the G-body spindle in all but one area...the steering arm is shorter on the S-10 spindle. S-10 steering arm is 6-3/4" long, G-body is 7-1/4" long. It will quicken your steering up a little bit.
Old 01-28-2011, 10:44 AM
thanks
Wow, just the info I needed. Would you know what year in particular for the S-10 spindle? 99 or so?
Old 01-28-2011, 06:12 PM
ericnova72's Avatar
More for Less Racer
I don't know the particulars on the anti-lock parts of the S-10 spindle years, but for the S-10 spindle in general the ball joint attachment points and other dimensions are the same for the entire production run of the S-10. You should be able to use any S-10 spindle you want, just pick one from a year with anti-lock brakes if that is the feature you are after.
Old 02-06-2011, 07:45 AM
end result
It turns out that the stock El Camino can be retained with the use of the 99 S10 backing plate/speed sendor ***'y and S10 rotor. Fits like a glove!!
el camino drop spindles 1979 Camino Suspension - Brakes - Steering 5 08-31-2008 05:04 PM
79' El Camino Drop Spindles? '79 camino Suspension - Brakes - Steering 3 02-02-2008 03:03 PM
Drop spindles for 1979 el camino '79 camino Suspension - Brakes - Steering 4 01-27-2008 05:06 PM
Can I weld a tab on my front spindles? Quarter Flash Hotrodders' Lounge 15 10-09-2006 02:25 PM
Front spindles and Rotors QUESTION!! 39chevy Suspension - Brakes - Steering 9 12-14-2003 01:59 AM
