Elco fuel gage problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2009, 05:46 PM
1980 Chevy El Camino
I replaced the fuel tank level sender after insuring that the gage would go to empty by grounding the wire that connects at the tank. It appeared that the in-tank sender was defective. Dropped the tank, replaced the level sender, voila all works. That is to say that it worked for about a minute and failed open. Tested the wires again and the sender is open electrically.
OK, what am I missing?
Old 06-13-2009, 10:01 PM
Have you rechecked the ground wire on the sender? You need a good ground from the body of the sending unit to the frame.
Bruce
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 130 02-03-2008 09:12 AM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
fuel problem? Big Blue Engine 7 05-26-2005 06:47 PM
fuel gage response time djenn Electrical 1 03-19-2004 03:38 PM
