elde blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2012, 07:22 PM
elde blues
my son and i have a 86 ford we just put a 92 5.0 with a fomoco alum. intake 1405 elde carb c6 tranny timming set at 10degrees we cant get it to idel under 1000rpms with out dyeing and we have to give gas when we put it in gear or it will die its a real dog we have tryed plugs played with timming check for air leaks we pulled carb off and the bottom was soak and wet there is no comp it has only 4 vac lines iam trying to keep it simple 4 him he just turned 16
Old 01-03-2012, 09:13 PM
Greg T's Avatar
www.krusinklassics.net
Going to need some pertinent informaion. First of all, have no idea what an "elde" carb is. Edelbrock, maybe? And I'm thinking a 92 engine is probably supposed to be computer controlled? I see where you say "no comp". No computer? No compression? Is there a regular HEI distributor with no computer control? If you want answers we need info.
Old 01-04-2012, 10:15 PM
yes it is edelbrock carb and it has no computer it does have a one wire hei dist. and its 1992 5.0 we only have 4 vac. lines going to plug all them off and see if it acts anybetter before i pull the carb
Old 01-04-2012, 10:34 PM
Greg T's Avatar
So, you have 4 wide open vacuum lines at the moment?
Old 01-05-2012, 02:47 PM
Make sure you don't have more then 7 psi fuel pressure wise but 6 psi would be the best bet as Edlebrocks don't like to much fuel pressure as that won't affect your idle per say but you said the carb was soaked when you took it off. Make sure you check your idle mixture screws settings as well if they are to lean when you put it into park it can make it stall like that. Also do you have a performance cam in this thing as anything bigger then stock will take more timing in order for it also to run right.
Eric
Old 01-06-2012, 08:23 PM
the idel screws arent changing anything right now i plug off all vac lines still cant get it to idel advanced timming still no change i will rebuild carb over the weekend this is a very old carb it has been rebuilt in the last 30days so i was told and it looked like it has been rebuilt but i dont know what jets were used or metering rods were changed i have checked timming vac leaks the only thing left is carb or the ford intake i have wont work with my heads but i realy hope this isnt the case what do you all think about useing a 2in spacer between cab and intake
Old 01-06-2012, 09:22 PM
DoubleVision's Avatar
Its obvious your flooding it to death. Is the vacuum advance in use? When the carb is flooding the idle mixture screws don't respond. This can also be caused by the throttle being open so far its pulling from the main boosters instead of the idle circuit. Edelbrock carbs don't like anything over 5 psi fuel pressure, if you don't have a fuel pressure gauge get one otherwise your shooting in the dark. Are you using a mechanical fuel pump or the in tank electric? If the in tank electric is used it has to have a fuel pressure regulator otherwise the fuel pressure will be way too high. First off find out what the fuel pressure is, then once we know what it is you can take the needed steps to fix it. If the fuel pressure isn't the problem then either the needle is stuck open in the seat causing it to flood or the float level is too high. After you get the flooding issue contained we can move on to the timing.
Blues Nightfire Off-Topic 8 11-08-2006 02:56 PM
C6 Blues Gemini Transmission - Rearend 10 06-09-2005 06:03 PM
305 blues camaronewbe Hotrodding Basics 15 09-14-2004 04:44 PM
Q-Jet blues malc Engine 8 07-10-2004 08:03 AM
GM HEI Blues Mista_T Electrical 18 01-14-2004 10:46 AM
