Just bought a studebaker pu with a 305 chevy found out that it had a 1406 carb and should have a 1403 500 CFm if I change carb to a 1403 will I get better gas millage with the same performances thanks Ronnie
What other mods do you have?
What intake?
What cam or type of cam?
What distributor?
Headers or not?
What tranny?
What gears?
All factors in your timing.
Best way to figure your best initial timing is bump the initial up until it pings or is hard to start when hot. Then pull it back 2 degrees. That would be your initial. You want a total of around 32 degrees all in by 3000 rpm. Subtract your initial from 32 to see what mechanical timing you need.
You'll need a dial back to zero or digital timing light to set timing because your timing tab might not go higher than 12 degrees.
So you just gotta experiment.
Where do you live?
I live in alto nm we are at 7000 ft I'll play with the timming the engine is suppose to be a 305 cod it is stock except for the I date its a elderbrock with a 1406 that's the way I bought it runs great except sometimes on excellation it surges thanks for the info Ronnie
Thanks a lot I haven't had a sbc engine for a long time and time got me I'll play with the timming tomorrow anything else, the engine runs great sometimes a little heastion when going real slow and try to speed up again thanks I need help Ronnie
Thanks just had the 1406 rebuilt and we changed the jets my auto parts called elderbrock and got jettings for 7000 ft truck runs good except at lo speed trying to give it gas my gas millage sucks but it's 4x4 1988 s10 chevy chassis Ronnie:welcome:
Thanks the new jets we put in was a little larger than the factory jets reminber I live at 7000 ft going up dwn mountains I love the truck just trying to make it better thanks for the info Ronnie
The timing tab on a 305 is at the 12 o'clock position on the cover. You need to look between the water pump and the cover to see it. Might be a circular tube down there to.
stock 305 with an edelbrock will likely want about 12-14 degrees at idle, 35-36 max, on 87 octane, probably the medium set of advance springs.
the stock setting for the carb will be VERY close for a stock engine, maybe a HAIR, just a HAIR lean when on the primary step of the metering rods. Your accel pump will need a little adjustment- they always do.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
