Eldorado power jump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2010, 08:54 PM
Eldorado power jump
I have a 1981 Cadillac Eldorado. I would like to know if any of the other big block caddy engines will match up to the THM325 tranny and what other problems I might have.
Thanks
Cam
Old 05-29-2010, 09:31 AM
Thanks
Cam
The TH325 uses the same BOP bellhousing as all other non-Chevy GM motors from the 1960s-1980s. Unfortunately, you have two problems. First, the TH325 is based on the TH200 and will not survive under any kind of torque. Second, your Eldo could have either an Olds 307 motor or a Caddy 368. The Caddy and Olds motor mounts are completely different. If you do have a Caddy motor currently, then other Cad motors should bolt in. If you have an Olds motor currently, then other Olds motors should bolt in.
Old 05-29-2010, 06:06 PM
Eldo help
Joe
Thanks for your info. I thought I read somewhere ounce that the THM325 was part of the THM400, THM425, THM325, THM3254-L. series.
Cam
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
