I'm a little stumped. I tapped wires from my electric window motor to the trunk for a remote switch in the event the poppers quit. (I have a remote button for the driver's side popper, but I'm a belt and suspenders guy....)
So I hooked up a DPST and shot it the juice, ground to one side, hot to the other side and it didn't move. I switched sides... nothing, but the wires did get a bit warm.
That didn't work. Why not? Obviously the DPDT window switch is still a factor in the circuit, but I thought it would leave the PW motor open on both poles.
A drawing of how you connected it would be very helpful. You need to make sure at a minimum that your remote switch disconnects both sides both + and - to insure it does not interfere with the windows normal operation
IMO..... wire your relay into the hot wire that rolls the window down. (depending on how your window switches are wired)
IF your window motor switch(s) maintains a common ground and connects a hot, you can interrupt that hot wire with a relay and provide an alternate hot source to operate the window motor.
As mentioned above, need how you have it wired now. If its not like my example, I'd be happy to draw you up a wiring diagram.
IF you can not determine the pin-out of the switch you can add a second relay to interrupt the neg wire.... hook the second relay up so that it provides a ground instead of 12v
IMHO, there is no reason to make this complicated by adding a relay. I would wire in a remote switch though I would use at least 16 ga. wire to handle the load of the longer run.
I can see your point of view, but since only the "down " circuit is necessary and to one window a momentary rocker/push button switch and and a couple of lengths of 16 ga wire should be sufficient. Naturally it all depends on which way Mitchman wants to go.
It would have to be a pretty hefty momentary switch for contacts to carry the load that the motor will draw..... relay will easily carry the load and a very small momentary switch can easily carry the load of the relay coil..... just my opinion. I agree his project, his money etc....
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
