elect oil pressure guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2004, 05:29 AM
ok not long after i changed my oil, my gaged started reading 100 psi, normally it sits around 60psi. also it seems to be working backwards but not with nearrly as many psi. ive changed the sending unit twice and im starting to get frustrated so any info will help greatly. btw int a auto meter ultra-lite electric oil press guage
Old 10-14-2004, 06:06 AM
poncho62's Avatar
Wiki Edits: 5
It has always been said that electrical guages are not as accurate as mechanicals. Don't know if that is true today with the newer technology.
You may have a ground problem. That is usually the problem when the "factory" electrical guages screw up.
Old 10-14-2004, 06:36 AM
ill have to check it out, but im pretty sure its still grounded on the fire wall
Old 10-14-2004, 01:58 PM
docvette's Avatar
Wiki Edits: 12
Gauge
Doc here
Check the sender wire, to be sure it hasn't broken or fallen off the sender.
On Electrics When they receive No signal, they peg high...
If the wire is good, measure the sender to ground with a DMM, It should read between 30 to 100 ohms (with wire disconnected)..If not, the sender is bad, Get a new one and try again.
Doc
Old 10-14-2004, 02:48 PM
thanks doc ill check it out
