Electical,brake lights switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2005, 08:45 AM
I've got a pressure switch in my brake line that takes a lot of foot pressure to activate the brake lights.What would be a good switch to use,more mechanical,like the ones used under the dash when a hanging brake peddle is used.My car is a 36 Ford Hotrod.Thanks
Old 07-24-2005, 05:06 PM
You can't beat the pressure switch. They are easy to find and not expensive so I would just get a new one, after I made sure there was not any residue blocking the opening of the old one.
Trees
Old 07-24-2005, 05:50 PM
Wiki Edits: 49
I've never had good luck with pressure switches. Try a good mechanical switch, they never seem to give me any problems. The one pictured below is available from Ron Francis and runs about $20.
Old 07-24-2005, 09:08 PM
302 Z28's Avatar
I also have had bad luck with pressure type brake light switches. they take too much foot pressure to activate. I tried several new ones of different makes, all the same. I went with the machanical switch prictures previously.
Vince
Old 07-28-2005, 08:51 AM
painless 80171....low pressure switch. Been under the hot rod for about 4 years...no problems
Brake lights problem 406S18 Electrical 11 05-05-2005 04:13 PM
Help Wiring A Relay to A Dash Switch horvath Electrical 6 03-06-2005 01:58 PM
Backup Lights Switch Question horvath Electrical 5 03-05-2005 06:47 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
