Electric auto choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2013, 01:29 PM
Electric auto choke
Does anybody know where to hook up the positive wire from the carb seems like where ever wire it the 12volt resistor gets to hot any info is awesome and greatly appreciated thanx
Old 04-03-2013, 06:22 PM
Faith - Respect - Trust
Welcome aboard, if the car is a numbers matching, rare 61 Ford, your better off to keep it the factory color. Seeing that your planning on a few custom touches, paint it whatever shade of Black you like.
As far as the positive wire to the Carb, do you mean a wire that goes to an automatic choke?
Ray
Old 04-03-2013, 08:30 PM
Banned
welcome , Just remember if the body is not perfect Black shows everything !!!
Old 04-03-2013, 10:31 PM
Yea I followed the edelbrock directions and went to key accessory and the resistor gets to hot as well as the automatic choke I'm sure its just a matter of messing around with a few different spots but being an older car I figured I would just ask thanx
Old 04-04-2013, 06:49 PM
Try hooking the wire up to the fuse box to a spot that's labeled IGN, or ignition, that way you have current going to the choke when the key is in the on position only and have a consistent 12 volts going to the choke when the engine is running.
Hope this helps
Ray
Old 04-05-2013, 01:31 AM
JeffB's Avatar
On my Ford I ran a 12 gauge wire from the choke to the "I" terminal on the solenoid,been fine for over 4 years.
Old 04-05-2013, 05:09 AM
EOD Guy's Avatar
I wouldn't recommend, running a wire from the "I" terminal....... It's only hot when the key is in the start position. So your choke would only be engaged for a few seconds, and if it starts ....... you really don't need a choke.
Old 04-05-2013, 01:11 PM
JeffB's Avatar
I think you mean the "S" terminal aka "Start" terminal,put a test light to the same "I" terminal to confirm voltage it is also is supplying 12 volts to my HEI I don't think the car would run if the voltage was not at the terminal.
Electric Choke 55 CrownVic Electrical 2 02-14-2013 07:16 PM
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 05:14 PM
electric choke njbloodline666 Electrical 15 05-02-2006 05:55 AM
Electric choke 3100 Special Engine 10 04-23-2006 08:46 PM
electric choke SDSJap Engine 1 08-13-2004 08:41 PM
