Electric brake vacuum pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2009, 10:21 AM
Good morning People. I have a 1960 Impala 2 door hardtop with a 425 horse 396. My problem is I have very little if any vacuum for the power brakes. I am still running the stock drum brakes on the car . I bought a no name electric vacuum pump from a local dealer a few years back and now just got around to installing it. Back when I bought it I was told it was a continuous running pump. Does that sound right! Im just afraid it will start to heat up and quit. I also added a cut-off switch from SSB products and now it seems when the pump starts to reach it's capacity it slow's down but does not come to a complete stop most of the time will this damage the pump Also when hooking this thing up I pretty much eliminated what little vacuum I was getting from the engine. Can I run off the pump entirely or do I have to plumb it back to the engine. I have not driven the car since i did this Your help would be greatly appreciated. Thanks
Old 03-26-2009, 10:34 AM
Joe G's Avatar
Registered user
Personally, I would run the brake booster solely off the vacuum pump. The switch you have should turn the pump off completely. I don't believe the typical vacuum pumps are rated for 100% duty cycle, but I am sure that listening to the pump run constantly would drive me 100% nuts.
Good Luck
Joe G.
Old 03-26-2009, 10:42 AM
electric brake vacuum pumps
Yea I was thinking the same way. as far as the vacuum pump not turning off I wonder if the pump is waek and struggles to reach the switch settings i will have too hook up a vauum guage to find out exactly what it is putting out. Thanks for the info.
Has anyone here done an Electric Parking Brake? Ripped Suspension - Brakes - Steering 18 10-09-2012 08:51 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
454 Ignition Timing Question leejoy Engine 58 09-13-2008 08:40 AM
Electric fuel pumps - Marine vs. Automotive Centerline General Rodding Tech 1 07-21-2008 03:12 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 05:07 PM
